Old 06-07-2012, 06:41 PM
Default Medium light set up
How much lower will the action be setup for medium light strings?
Des
Old 06-07-2012, 10:41 PM
Lower? From mediums? The G and D are the same. The A and E (and B for 5s) are lighter so, you will need higher action, not lower action to maintain the same tension or feel.
Old 06-26-2012, 11:01 AM
Lower? From mediums? The G and D are the same. The A and E (and B for 5s) is lighter so, you will need higher action, not lower action to maintain the same tension or feel.
I want to lower the action so I can play lighter. Its hard to tap and double thumb due to the high action. Another reason why I want to start using medium light strings.
Des
Old 06-26-2012, 12:03 PM
You can lower the action and maintain tension easier with the TCRM than with ML.
Old 06-13-2017, 02:03 AM
Gerson Lazo Gerson Lazo is offline
Gerson Lazo is on a distinguished road
Default Can you elaborate?
Hi Ken,
How does this work? Why would be easier on Medium than Medium light? Does this same concept applies to Burners TC ?
Thank you!
Old 06-13-2017, 04:40 PM
Originally Posted by Gerson Lazo View Post
Hi Ken,
Thank you!
Lighter strings move more then mediums. Mediums can be lowered and keep more tension than lights. You have to play lighter on lights and can dig in more with mediums.
ML had M tops and L bottoms. Not as balanced as Ms or Ls across the set.
Old 06-13-2017, 04:42 PM
So if my playing was crazy light and I'd like a crazy crazy low setup, should I go for mediums ? I'm talking about lowering the strings as crazy as 2/64 ...
Let me know,
thank you for your time Ken,
Old 06-13-2017, 11:48 PM
Let me know,
You wont know till you try it.
Old 06-14-2017, 01:26 AM
And on your experience, what has worked better for this purposes ?
Old 06-14-2017, 02:09 PM
I don't use a set-up like that but also never used lights for any period of time.
Old 06-14-2017, 02:12 PM
I see. Then I'll give it a try and find out!
Thank you Ken,
