Old 05-13-2007, 02:40 PM
Dan Berkowitz Dan Berkowitz is offline
Dan Berkowitz is on a distinguished road
Default American Standard setup?
I've had a '60s American Standard upright since the early '80s, but I've never been that happy with how it sounds. In particular, the E string sounds choked and lacks depth/punch. The whole bass is a bit midrangy.
My main use is for swing or acoustic blues, although I occasionally do some arco for classical stuff...but certainly not my main use.
Two different shops have looked at this bass. One shortened the soundpost until it would barely stay in, along the way finding it had been installed sideways before. The second shop added a shim onto the bottom of the soundpost to make it longer and moved the bridge up to shorten the scale to about 42" from its original 43+ inches.
With these moves, the bridge had been a bit too tall at one point, it was cut down and then sometime after needed to have the adjusters raised about 1/2". The string height is comfortable now and I'm using Permanents.
My question then: What should be expected from this bass, especially from the E string? I thought it was supposed to be a loud, big sounding bass.
And a related question: Is there something to look at that would eliminate the choked sound of the E string?
If it matters, the neck had been broken at the heel when I bought it and the repair job has held all these years. Recently, in cleaning and resealing the neck, I noticed that there is a fine crack running approximately parallel to the fingerboard for the first 8 or so inches. This may have been part of the original break, but I didn't see it until cleaning things up.
Also, it's virtually the only double bass I've played, other than in a shop.
Suggestions?
Old 05-13-2007, 03:20 PM
Cool Suggestions..
Suggestions?
Pictures of all this would be better for discussion. I do have 2 questions for you.
1) What is the 'Neck Stand' of this Bass? (the distance between the Top and the bottom edge of the Fingerboard where the Neck meets the Top/body).
2) What is the height of your Bridge at the center from the Top to the top of the Bridge between the D and A strings in the middle of the Bridge with the String height off the Fingerboard about 5-6mm under the G and 8-10mm under the E at the end of the Fingerboard?
Before other problems can be addressed it is important to know how the Neck is set and the flexibility of the set-up heights of the Strings. Your Bass already has some severe damage that could cost more to fix traditionally than the Bass is worth. This is mentioned in a New Thread "What's in a Set-up?" Try reading that and see what might apply to your Bass. Again, pictures will make it easier to answer your questions. The 'E' string is most often weaker sounding than the 'A' on the bottom end. This is the nature or our Beast but taming it is often one for the Pros.
You may need to get your Bass to a better Shop more on the lines of Jeff, Arnold or Nick. I don't know who is closest to you that does their level of work but John of CSC/Shen knows a lot of shops in the country and might be able to suggest one.
Old 05-13-2007, 03:30 PM
Lightbulb Revision..
Ok, I looked at your profile and pulled up this pic on your 'My Space';
The Neck stand looks to be about 20mm or less give or take from this photo. 35mm - 38mm is more of what I see coming out of the better adjusted/made Basses today. This allows for more bridge height and with less pitch of the Neck which lessens the tension as well. This can help many Basses that sound choked from too much tension on the Top. Also, that Bridge looks on the low side (maybe 6" in the middle) and looks warped towards the Fingerboard.
I picked up an old Kay in trade recently and I am having the Neck moved out and then a New Bridge fitted with more height off the Top/body but lower to the Fingerboard than it was possible before. Many of these old American Ply's need the same for optimum set-up.
Old 05-14-2007, 08:14 AM
Ken...thanks for making the extra effort to look up a pic of my bass. I just took the two measurements and you're real close...amazing!
The neck stand measures 25mm. The bridge center height is 6". String height is 9mm for the E and 5 mm for the G.
Perhaps it's time for a new bridge, given that it looks warped forward. The feet are seated nicely, so it's not just tilted. As you suggested, I'll see what shops I might check nearby. We're about 5 hours from Minneapolis, KC, Chicago and St. Louis.
Old 05-14-2007, 07:32 PM
I've heard good things about Chris Threlkeld-Wiegand, formerly of Robertson & Sons Violin shop, www.heartlandsbs.com. Also Jim Reck builds basses and may be a good source. They are both in Iowa City.
Old 05-14-2007, 09:48 PM
If you get that pickup out of the bridge wing you'll improve the tone. That gap was not meant to be bridged and is important for evenness. Also, your bridge appears to be tilting toward the fingerboard. How far is the soundpost from the f-hole? From the bridge?
