Old 12-13-2008, 12:30 PM
Heather Ross Heather Ross is offline
Heather Ross is on a distinguished road
Default Visable differece w/ plywood?
When you look at an unknown bass, how do you know if its carved or plywood? I would assume that w/ plywood, you'd have visible seams/gain changes.. I'm not sure if the top of my bass has these, or if its just my eyes playing tricks.Its my first bass (and i got a great deal on it for its sound regardless of construction), so be nice! I"m just trying to learn more
Old 12-13-2008, 03:05 PM
Hi Billy,
I can spot a plywood, but won't try to give advice here because there are people reading this site with vast amounts of knowledge who will, no doubt, answer your question much better than I could at some point. I just wanted to say that I have a plywood that is well set up and plays really well. I played it solo (arco), outdoors at a wedding yesterday, and it did a good job - I think that playing solo outdoors is a pretty good test for a bass, projection wise.
If I ever manage to get a carved bass, as I've been trying to do, I'll keep my plywood as a 'road bass' - I've used it to play with some pretty good jazz musicians over the years; it's never let me down.
Old 12-18-2008, 06:00 PM
Trix Miller Trix Miller is offline
Trix Miller is on a distinguished road
One easy way to quickly determine if the top is laminate or solid is to look at the edges of the f-holes. If it's laminate, you see several layers sandwiched together. That's assuming those edges have not been covered by some sort of spray-on finish that hides that detail.
Old 12-18-2008, 11:25 PM
Good point, though you can't see the layers there on my plywood, and they don't seem to be covered up. The lord of lamination works in mysterious ways!
Old 12-19-2008, 02:43 PM
Drake Chan's Avatar
In the more modern carved basses I've seen, the luthiers like to create a flourish towards the purfled edges on the top. The edges are usually carved a little higher than the purfled area next to it.
I haven't seen this done on Plywood basses, probably because it's not possible. With a carved top, a luthier can carve any section to his/her preferred thickness. But with a laminated top, the plywood sheets are glued together in uniform thickness.
Old 12-19-2008, 03:23 PM
I remember seeing and playing a double bass in a music shop in the 1970s or early 1980s that was made of metal (tin)! The neck was made of wood. I wonder where it is now?
