Old 04-10-2009, 04:06 PM
Default 'Wingless' Bridge
A friend of mine in Orchestra London has no 'wings' on his bridge. I asked him once why he did this and he said it makes the sound much more "direct and focussed".
Here is an example of Andrew Miller and his lovely bass: http://dailygleaner.canadaeast.com/front/article/462348
Does anyone know of this practice?
Thank you kindly.
Last edited by Calvin Marks; 04-10-2009 at 06:12 PM. Reason: Addition of Photo Link.
Old 04-11-2009, 09:47 AM
John Feeney (world-class classical bassist in the NYC metro area) has a bridge like that. He likes it. I don't have any real-world experience with discerning the difference between this and a "normal" bridge. Someone (you, Calvin?) should cut their bridge down without changing anything else, then report here on the result. Perhaps someone who is about to have a new bridge cut can do it to their old one?
Old 04-12-2009, 07:56 PM
Okay, I've done some reading on this topic and I found a wbsite which contains a bit more information: http://www.rivinus-instruments.com/DesignConcepts.htm (Two thirds down the page).
To summarize, the wings of the bridge act as a dampening device. On an instrument which is generally shrill (like the violin), the wings cut down on the penetrating tone and add a bit of depth to the sound.
For Double Bass, (perhaps an ultra dark instrument) it may be a good idea to remove the wings since it would bring more focus and clarity to individual notes and perhaps increase resonance and volume due to the decreased mass on the bridge.
However, this may not work for brighter instruments as this could result in a penetrating tone to the ear.
From everyone I've spoken to with these bridges, the instruments clarity has always improved and volume has increased.
I will speak to Don Gorman about this considering that his instruments are by nature very dark in sound.
For someone doing auditions it may be good to have a slightly more focussed sound so you could project in the hall.
I believe Joel Quarrington uses this type of bridge, perhaps he could chime in?
Thanks.
Old 04-13-2009, 12:27 PM
Default My experience
Dear friends i saw this bridge two years ago in Brighton, UK, in a performance of a local Symphonic Orchestra. The bassist told me that this bridge enhances clarity and makes a dark bass brighter. So i cut one of my bridges accordingly. I placed it in my darker sounding bass and the arco response improved dramatically, giving better trembles and a more focused sound. The piz sound, however, didn't changed in the same extent. My teacher ordered one of these bridges for her 100+ years old bass and when she put it on she said that it improved the sound of the instrument. This is my little experience in this wingless bridge. Now i'm working one for the principak bassist in the local Symphony and i'll inform you for his comments.
Old 04-13-2009, 01:09 PM
Great, can't wait to hear the results.
Old 04-13-2009, 02:47 PM
Joel Quarrington Joel Quarrington is offline
Joel Quarrington is on a distinguished road
OK, since you asked I will submit my two cents here!
I agree with the observations people have made so far but I am surprised because I thought the use of these bridges was quite well-known.
These "wing-less" bridges were introduced to me over thirty years ago by Ludi Pollak, the wonderful repairman and bassist in Toronto. He and his father were well known luthiers in Bucharest before coming to Canada and one of their clients was Vladamir Orloff, the great cello soloist. Orloff was practicing one day and mishandled his bow; he accidently knocked the wing off his bridge on the C string side, and was amazed at the increased volume and focus in the sound.
With the Pollaks help, he developed this into a belgium-stlye bridge with no wings. When Ludi and I started playing together in Hamilton back in the seventies he made me one and I have used one ever since and have learned alot about them.
They will absolutely make your bass more audible and easier to hear in the orchestra and they make it much easier to bow for some reason.
The wings are tone filters for the high end frequencies and are really just little mutes on the bridge; ultimately you can control better how "dark" your bass is. If you want clarity but not so much treble in the sound, than don't cut the wings but just try and get the overall weight down. I can't remember the exact numbers now, but at some point I was fairly into all of this. I think that a normal bridge might have been around 140 grams? (my numbers are probably all wrong), I think I thought the magic number for me was 120, but I am not sure. My friend Wolfgang Guettler was also into this; he had a bridge that was so thin; maybe 100 grams! he took a bridge, cut it in half and had a thin veneer of ebony inserted! This prevented it from warping, which I should mention is the biggest problem with a low mass bridge.
I don't recommend these bridges for all basses! If you have a dark bass that is hard to hear when you play in orchestra, then you have a candidate for the "procedure"! (You used to have to go to Scandinavia for that!)
Having a wing-less bridge on a bass that is already clear and open (bright) can be a real pain to listen to. It all has to be done with taste; with my style of playing you have to hear yourself play all the time so having a bridge like this is helpful but you don't want to inflict yourself too much on your section mates.
I would be cautious about showing up to an audition with a wing-less bridge if it isn't held behind a screen. I think that many of the notions of a dark set-up and "blending" are not compatible with the clear and open sound of a low mass bridge. Just seeing that you have no wings on your bridge might indicate to some people that you are not going to "blend".
Personally, I think that the best blend comes from everybody having great intonation and rhythm and that is only possible if you can hear what notes you are playing, sort of like the way all the other instruments work.
I would also like to mention that the best sounding bridge I have heard lately was made by my student, Ian Roberts, and it looks normal (with wings!) but it is very light. The quality and density of the wood make a big difference as well. If you use adjusters in your bridge then cutting the wings off can counter the effects sometimes; I am not a fan of metal adjusters, but for me, they become bearable with no wings.
I have sometimes wondered how and who decided on the modern shape of the double bass bridge that we have inherited today; I have seen on some old basses in museums etc..bridges that share many qualities with wing-less bridges, for instance low-mass, high arching, no feet, not to mention no wings!
