Anybody out there using the RS as their main pick up?
I have an Upton Hawkes, and the pick up was fitted by the Upton guys. Anyway, the problem I am having is that the lower notes are sounding pretty heavy, and as I go up to the G string and keep moving up into thumb position there is a drastic loss of sound. I feel that I've tried just about every position moving the pick up around, and also tried switching it face down. I am also used to the Realist on my other basses, and the RS seems almost too "airy" sounding.... But thumb position is just dead! ![]() |
Have you called the Uptons?
Sounds like a grounding issue. When I first ordered my pick up from Upton I had it installed and took it to a recording session right away. It sounded like Gary Peacock on a high end EQ fueled by crack. Hahaah. And when I put it ribs down on the ground it sounded fine. Big and full. Pull the bass up and I sound like a pair of near field monitors with a Broken tweeter. Call them up and get a replacement pronto. I think these pickups are great. Very natural but they seem very fragile. And it sucks cause if you used an underwood before like I did you have cut some room for the Revolution. Great pickups but very fragile. Good luck.
I have not called them.
I recently purchased this bass used. It was sold back in 2006, but it seems like it just sat at this guy's basement for a long time. I've been using the Realist for about 12 years or so... pretty much since it came out. And I am very used to that sound and how it responds. I initially like the RS and I am hoping it works out for me. I played a gig today an thought it sounded a lot better. i think I found a better spot for it and I marked it with a pencil. I am not sure this is the sweet spot yet, but it sounds much better. Question: Although I am getting better response, I am running it through a GK 150 combo, and I am currently setting the highs at about 9 o'clock, low mids, and high mids at about 10 o'clock. That seems to calm down the high frequency, piezo like sound. And as I need to turn up the volume I find myself bringing those frequencies back even more. And as I go up into the high range of the bass it definitely sounds kind of trebley. so the question is ; is that more of a characteristic of the type of pick as if I were comparing it with the Realist, or I haven't found the sweet spot yet, or maybe this one is just not working properly, or... something else...? Thank you. |
