Old 10-22-2012, 06:10 PM
Joshua Phelps's Avatar
Default Loose straplok screw
On one of my bsr shaped smiths the front strap screw loosens up very quickly after its been tightened. The threads on both the wood (walnut) & screw are perfect & when you tighten the screw all the way you can feel it tighten snugly into place without feeling like its going to strip. I know about the wood glue & toothpick trick to dowel the hole & redrill it but was wondering what other smith users would recommend. I was thinking about some very thin shaved slivers of toothpick in the hole with NO glue might do the trick & also not be permenent.
Old 10-22-2012, 06:13 PM
Also, these are flush mount straploks
Old 10-22-2012, 06:42 PM
I'd use a bit bigger screw and drill a slightly bigger hole in the knob since I don't like messing with the wood too much.
Old 10-22-2012, 06:58 PM
Default larger screw
one thing i am 100% positive on is that a larger screw is NEVER a good idea. the wood you remove from the inside of the hole can never be put back, its better to dowel the hole with glue & toothpicks rather than going larger. my issue is that the screw fits & tightens when screwed in it just loosens.
Old 10-22-2012, 07:23 PM
Hey ken,
What do you guys do at the shop when this happens?
Old 10-22-2012, 07:33 PM
Originally Posted by Joshua Phelps View Post
Hey ken,
It never does unless it's an older bass coming in for set-up, TLC or repairs. It is not that common. If it does, we either put a small 1/8" dowel piece in with a small bit of white glue and them put the screw back in or if the hole is worse, we glue a dowel in, let it dry and re-drill but the dowel is usually softer then the body wood. When trying to fix your bass yourself, be careful not to make things worse. If you are not really sure of what you are doing, then don't do it.
Old 10-24-2012, 02:44 PM
If you say so.
By doing that, the idea was that no more wood would be removed - don't see why it should (just a slightly bigger screw, enough to keep it tight).
I'd rather do that than dowel and then drill a new hole, but hey, that's me.
Old 10-24-2012, 04:21 PM
Exclamation screw size
If you say so.
With strap loks, you can't just use any screw. If the Pin with the ball bearings do not lock into place because of a Screw changing the depth of the space for the pin to enter and lock, then you will have a damaged bass when the strap flies off the bass.
Jens, your suggestion might work with other applications but in this case, I think some caution must be exercised when you have exact needs for the fit of the Locks.
