Old 05-10-2007, 04:04 PM
Sercan Say's Avatar
Sercan Say Sercan Say is offline
Sercan Say is on a distinguished road
Send a message via MSN to Sercan Say
Default What makes a Double bass good for Jazz or Classical?
I'm from Turkey, here I'm working with a luthier he built several double bass, but he ordered woods cut in the shape, so he made thickness adjustments and put it all together.Now we will cut , carve woods.
What I want to know is If we want a double bass has good pizz. sound do we have to choose different woods ? Or are there any other major adjustments with wood thickness or something like that?
And same questions for Classical sound.
We recently built-one It has 5/4 body and 3/4 neck with 41,3 scale lenght, It has very full very nice bow sound but pizz. sound not that much better It has good pizz. but bow sound much more full than that.
Old 05-10-2007, 04:45 PM
Cool 5/4 body and 3/4 neck??
Would you mind telling us ALL the dimensions and not just the 5/4 size so we can see what you are referring to. To this day, I still don't know what people are calling 4/4 or 5/4. Most of the people I talk with call them all 7/8ths as a true 4/4, so they say, would be too big to play for the average person.
On the sound, I don't think woods or design or anything one thing will make a Bass good for Pizz or Bow. Good is Good and many of my Basses are great for either style. Some good commercial jazz type Basses are just bad with the Bow unless set-up for Classical playing and even then, they are student grade at best and do not Pizz well for Jazz unless re-strung with other Strings.
This may be trial and error for a new maker so I suggest you consult Jeff and Arnold who both make some great Basses.
Old 05-10-2007, 05:02 PM
Sercan Say's Avatar
I dont have dimensions but I'll try to get them.
I understand sound issue, I think final setup and strings are effective in this issue.
This bass has one problem too, when we hit F# on the E string with pizz. suddenly volume decrease and then increase.We cant solve this problem.I will put some pictures and maybe some sound sample If I can
Recently we built 2 other bass too they have nice sounds pizz. and bow as you say.
Old 05-10-2007, 07:02 PM
When you talk about a good jazz sound, what do you mean? Old style thump, whining growl, fat and punchy? Different preferences would dictate the maker's approach. For example, if a client told me he/she wanted a strong upper register and moderate bottom, I would increase the arch height and keep the top a bit thicker. The opposite for a bottomy, thumpy sound...
Old 05-11-2007, 05:45 AM
Pongsak Sooksawak's Avatar
Pongsak Sooksawak Pongsak Sooksawak is offline
Pongsak Sooksawak is on a distinguished road
That why my bass has a very strong upper and moderate bottom. Also, My baby is so heavy.
PS. I don't know the original of my bass.
ID:	191Click image for larger version
ID:	192Click image for larger version
Old 05-11-2007, 08:52 AM
Lightbulb Origin...
Attachment 191
Attachment 192
Attachment 193
I would like to see the rear and sides of the pegbox/scroll and the sides vies/profile of the Ribs as well. It looks like a 1920s - 1930s French Bass to me. This style has seen labels like Bisch, Collin-Mezin, Quenoil and a few others.
Old 05-11-2007, 09:52 AM
[quote=Pongsak Sooksawak;4073]That why my bass has a very strong upper and moderate bottom. Also, My baby is so heavy.
Plus, the shape of your bass prevents it from being deep-sounding. Generally, basses with small, sloping shoulders (regardless of the lower bout size) have a penetrating sound, but little in the way of bottom.
Old 05-23-2007, 05:29 AM
Sercan Say's Avatar
I have all the dimensions now
Body height : 120 cm
Upper bout width: 53 cm
Middle bout width: 42 cm
Lower bout width: 76,6 cm
Neck length : 45 cm
Playing string length: 103 cm
I forgot the measur Rib depth but I'll do it today.
We have this problem with F#, when hit F# volume changes, and note is out off tune.We don't know what the problem is we changed sound post, strings, fingerboard , scale length.Maybe problem is about body dimensions?
I took a video when I hit F# you can hear our problem other note seems okay.
http://www.4shared.com/file/16463200.../SANY0314.html
Old 05-23-2007, 06:41 AM
You have a resonance that is close to F# on your bass body that is very "easily" excited. You may be able to locate it and damp or change the frequency so it doesn't boom. I would start by having someone else help you find the resonating part by pressing in different places while you play the F#. If you find it by pressing on the top, then you can add some mass to that area in the form of sticky tac, plasticine or some other heavy clay type stuff. Once you get the right weight in the right place you can take the top off and glue in some wood inside and that damp it or shift the resonanct frequency of that mode of vibration. There is also a relationship between adding mass and removing stiffness. So that would be another possible approach. If you can't find the resonance by pressing on the bass body, then it is an air resonance and you can test that by taping over one, some or both ff holes.
Old 05-23-2007, 10:17 AM
Sercan Say's Avatar
We'll look about the body, but yesterday we closed one F hole with hand and for a second we lost that sound, we'll check the body for resonance but if it is air resonance what can we do about that?
Old 05-23-2007, 12:36 PM
Arrow U.S. #s
Neck length : 45 cm
Body height : 47 1/4" (120 cm)...Comments: 4/4 size
Upper bout width: 20 7/8" (53 cm)...Comments: 7/8 size
Middle bout width: 16 1/2" (42 cm)...Comments: 7/8 - 4/4 size
Lower bout width: 30 3/16" (76,6 cm)...Comments: 4/4 size
Neck length : 17 3/4" (45 cm)...Comments: "not a necessary measurement"
Playing string length: 40 1/5" (103 cm)...Comments: 5/8 - 3/4 size
This is a very unusual Bass measurement wise if the numbers are correct!
A long body with a wide lower bout and a short string length. I would assume this bass to have a potentially deep sound as the lower bout seems so big in length and width but the shorter upper bout may be fighting the tone making it sound thinner. The center bout also seems to be on the wide side as well.
I would like to hear Arnold's opinions on this but before that happens I would ask that you measure once more to confirm the numbers as well as my inch conversions.
Old 05-25-2007, 12:24 PM
Sercan Say's Avatar
Inch conversions and measurements are correct, my luthier said he ordered the body woods pre-shaped from Romania (If I remember correct).
The bass has really huge sound with bow but we cant say that for pizz. sound.And we still have this F# problem it is between F and G notes maybe this problem is about fingerboard dressing?
Old 05-26-2007, 09:00 AM
Now that I hear that again I think you need to dress your fingerboard first before you do any thing with the bass body.
You have a buzz on the E and A string, at least that is what I think I am hearing. Try finding where the string is buzzing. Jeff Bollbach's trick is to put some chalk on the bottom of the string and then retune to pitch and play. The chalk will rub off on the fingerboard and show the spot to scrape.
It sounds like the buzzing is in the area of the first position. My approach would be to remove the E by loosening it and moving it off to the side. Scrape the fingerboard under the E from where the nut butts against the fingerboard up to about F or maybe F#. Put back on the string and listen for improvement. Repeat as necessary. Once good, do this with the A string.
If this doesn't help, you will need to pop off the nut and plane the fingerboard down with a handplane. Start from about A on E string and plane towards the nut end.
