Old 01-31-2007, 06:57 PM
Default Set up differences/jazz and classical players
I've been curious about the priorities and methods of general bass set up.
As a relatively inexperienced player, compared to others here, I have a lot to learn, but I've played a lot of different basses, both at jazz jam sessions, and shops catering to primarily classical players or jazz players.
At a recent jam session I had the unexpected opportunity to play a few tunes on a Prescott bass that cost upwards of $25K. The strings were hiked up higher than any bass I've ever played; so much that it was painful after just a few minutes. It did put out some sound though, but if you can't play what's in your head, what's the point. I'll be going back for more this weekend.
At the other extreme are basses with fb's nearly straight and strings almost touching the board. These are the easiest to play, but you give up some volume.
I'm somewhere in the later camp for sure.
At the risk of opening a can of worms, I wonder if we could benefit from a discussion: How to set up a bass for various styles of play. What are the considerations for planing a fb, cutting a bridge etc. How do they differ for pizz and arco play.
I understand that the there isn't a Jazz setup or a Classical setup, but rather a combination of elements that accomodate a particular players style and wishes.
Thoughts anyone?
Old 01-31-2007, 11:48 PM
Cool Set-up re-posting..
I gave a few answers in another Thread here and suggested to Greg to start this new Set-up Thread. I would like to post my previous replies and thoughts to start and get this ball rolling.
All the guys I have used for repairs and set-ups in the past do work for all types of players.
I have seen quite a varied preference of height, width and arch from both Orchestral and Jazz players. I will venture to say that there is no such thing as a Jazz or Classical set-up at all but rather just preferred set-up Specs depending on the actual Player.
Set-up starts with the Bass itself and the Fingerboard radius you have. If you like a certain arch and the Fingerboard is over or under rounded for the way you like it, the Bridge arch will not give the desired height from string to string across the FB. In this case, it needs to be re-worked or replaced. If the Neck is set too low to the Top, it may be difficult to get the strings low enough. Re-setting the Neck stand is a common Professional modification that improves the possibility of getting the desired set-up.
As each Bass is different, it is important to have the Bass in its best possible condition before the set-up begins. If not, the work will be a compromise for a less that optimum set-up.
Old 02-01-2007, 09:27 AM
There are many set-up variations for both classical and jazz players. To generalize, classical players need more arch in the fingerboard, which helps with clean arco string crossings. Most jazz players like the board a little flatter in the arch, which makes it easier to cross strings pizzicato. When strings are set high, and the bass is to be bowed, a lot of fingerboard and bridge arch is required, and the strings may need to be spaced farther apart. That's because when you press an individual string to the fingerboard you move it down a lot compared to its adjacent strings. This makes bowing cleanly on one string very difficult. As far as camber (longitudinal scoop), gut strings need more. Players who pluck hard generally need more. Players who fire the strings downward (plucking finger toward the bass' belly) need more. A flattish arch is good for finesse players and easy-going bowers, also classical soloists. These are all generalizations; every player needs something a little bit different.
Old 02-01-2007, 01:39 PM
While there may be no "official" designation of jazz or classical setups, IMO, they certainly do exist as de facto standards. The great majority of my doublebass setups are for jazz players and while there are certainly exceptions, the great majority of jazz players who come to me want setups where the strings are as close as possible to the fingerboard, without any buzzing while pulling the strings as hard as they would ever pull them. This usually means a fairly flat arch and strings fairly close together. For most classical players, this would be the last thing in the world they would want for playing arco.
One of the first questions I ask a new customer is whether they want their bass setup for jazz or classical. Even if jazz or classical setups do not exist, the customers always seem to know what I am talking about.
Old 02-01-2007, 05:56 PM
When I bought my Upton, I told them I wanted it set up for jazz play with the strings close to the fingerboard. I wasn't experienced' enough to give any more information regarding string spacing or radius. The bass arrived almost exactly the way I expected although I might prefer less scoop in the fb and I did cut the nut slots a bit deeper. My teacher commented on the nice setup. Since his main bass was set up by Bob, I take it as a compliment. Aside from the sheer size of his bass, it's got an incredible setup and tone.
Question, Why do basses vary so much regarding tension? Is it the tailpiece , the thickness of the top? What is it?
Old 02-01-2007, 06:01 PM
You're not saying that a player should make the best of a fingerboard radius or scoop that doesn't quite fit their preference are you?
I would think that assuming the neck is set correctly, a properly planed fingerboard would be the first step. No?
Old 02-01-2007, 06:24 PM
Cool set-up..
I am saying that the Bass can only be set-up as good as the Bass is Neck wise etc. Fingerboard planing or replacing is a bit more than a set-up. I regard set-up as nut, bridge height etc. FB planing etc, is more of a repair to me to correct movement in the neck OR undesired cambering from a previous luthier. Sometimes it is just not how you want it.
I got this on Bass from the UK and it looked like it was adjusted for King Kong. The dealer said it was a standard London Orchestra set-up. I have to have the FB re-cambered, cut a new nut 1mm closer spaced per string, lower the strings and re-cut the bridge arch as well as move them closer 1mm just to play it and not be in pain.
That to me a a bit more than just a set-up but more common than you would think when Basses change hands. Just my opinion here.
Neck sets are often not optimum for playing from what I have seen. Ask Arnold and Jeff how often they re-set a Neck and the percentage of Basses that can and have benefited from this whether it was actually done or not.
Old 02-02-2007, 12:25 AM
I have always considered dressing/planning of the fingerboard to be an integral part of any setup. If the fingerboard is not right to begin with, IMO, it would be a total waste of time to do anything meaningful to the nut or bridge. I can't start to count how many times I've had people call me and tell me that they want the "action" lowered and "all the is needed is to lowering the nut and bridge". 95 times out of a 100, the "real" problem is with the fingerboard.
Old 02-02-2007, 02:01 PM
Applause!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
