Old 06-24-2010, 11:15 AM
Default Failed Scroll attempt
A distraught bass owner dropped this off at me , said that this repair lasted about a year , surprisingly so with a 6mm pine dowel and barely any glue at all on the surfaces.
Of course a scroll graft is the correct procedure but he needs the bass asap as he is in the middle of a recording / any insight on how to make a decent interim repair ...... BTW bass is from Russia ?
Old 06-24-2010, 12:09 PM
You would be joining end grain to end grain--a very weak proposition. I would not expect any repair to hold unless it includes a butterfly spline or "ironwork". I would advise you to walk away.
Old 06-24-2010, 12:16 PM
Lightbulb Scroll Graft?
If you are referring to those 2 pieces in your hand as the Scroll graft area then you are gravely mistaken. Gravely as far as the bass is concerned. That is NOT a scroll graft. Just an old pegbox/neck repair and poorly done. Actually, that is when it needed the actual graft of a new neck. Like Arnold said, you can't glue it there unless just to hang it on the wall, without strings of course.
This is what a scroll/neck graft is;
.. and after done, looks like this;
Old 06-24-2010, 12:51 PM
Herr Smith , I said that the proper thing to do would be a scroll graft (onto a new neck of course ), as you can see I labeled the failed procedure as you see it in the pic as a 'scroll attempt'.
Old 06-24-2010, 02:04 PM
Cool oops...
Sorry, reading here while at work I mis-read your post. I thought obviously that you said the graft was done correctly rather than the correct repair IS a graft.. My bad. Good.. we are on the same page here.
The ONLY repair I see here that will work IS a graft. Anthing else will fail in time and possibly cause more damage down the road leaving less wood where you need it to do a good graft. Now that it's apart and clean, it needs a graft, period. No way around it that I can see.
By the way, that's Arnold's work above on my former Prescott.
Old 06-24-2010, 02:35 PM
How do you manage to part with these gorgeous instruments ? Surely you must have regrets from time to time ...
Old 06-24-2010, 03:00 PM
Cool regrets?
Yes, I miss them for how they sounded the few times I used each one of them but in business, I must sell most of them and hold on to only a few. When a 'saved' bass kept for myself is admired by others and sold, I go and choose another. This is the business I chose to do so I live with whatever happens.
Old 06-30-2010, 06:39 PM
Hopefully it has been fixed by now, but I just saw the thread -
Neck Graft!
Don't "mickey mouse" the thing any more, and please everyone else... just give the bass a new neck!
Old 07-01-2010, 06:10 AM
" yesss sah ! " " sorry sah !! " " one scroll graft coming up , immediately if not sooner sah "!
Originally Posted by thomas erickson View Post
hopefully it has been fixed by now, but i just saw the thread -
neck graft! :d
don't "mickey mouse" the thing any more, and please everyone else... Just give the bass a new neck!
Old 07-01-2010, 12:31 PM
Adrian-I see the trip to the hills has given you a boost of confidence to become a graft warrior.LOL
Thomas, Although, I have always appreciated your sincere idealism, but from what I gather- a new neck might be overkil on this particular bass
"ASAP" If this means get it done and PDQ-well, it is not something that is luthier friendly-as my first mentor said to me many times "in this kind of work, it is always best to take your time"
Wayne,ain't no 'micky mousin' around here in the hills - I can strip and re-assemble a 4/4 with extension in under 5 minutes blindfolded. But seriously though,you are correct and in the real world it's not allways within a clients budget to afford the 'optimal procedure'.
Old 07-01-2010, 08:26 PM
What does "changing out a neck" mean? A graft? A whole new neck and scroll?
I don't think this is an appropriate forum for businesses to compare the prices they charge for their services. In fact, there isn't an appropriate forum, as doing so is illegal, and that is why the FTC exists.
Old 07-01-2010, 08:57 PM
Lightbulb well..
To answer and end this answer-less quest I will say that it depends on the job and the shop and the worker and the materials and more.
A Luthier in NYC charging $100/hr as compared to one somewhere else charging $50/hr will get you two very different prices and not just the rate difference.
What if the $100/hr shop takes 30 hours and the $50/shop takes 42 hours for the exact same job/bass/scroll IF there is such a comparison? What if the $100/hr shop puts the neck too far forward in pitch for an Extension? I have seen this and from a famous show and for about double the going price when it was done. A rip off in my opinion but the customer didn't know any better then. The Extension was basically useless in my book and the bass still needed another graft to make it right and another extension.
Gear repairs, removal, re-installation? All bass gears are created equal? Looking at all the basses here in my room I don't see two that are exactly alike so in the gear job alone if no repairs or mods are needed I see a different time and prices right there unless the shop is shortsighted enough to have a fixed price for all graft jobs. In that case, if they are still in business than they are overcharging the majority of the time.
The graft block! Do all Luthiers/shops put on the exact same piece of wood on ever bass? These come from home depot in a box, one size fits all? NO WAY. Every neck or graft block is individual unless you are buying one-price factory necks. I don't have that on my basses and they are not welcomed here. So, that is another factor. If I have a bass being done worth $200k I want the best piece of wood for the neck available on the planet and will pay for it. It wont be getting a factory neck if I'm alive and no one I take my work to would even consider the suggestion. In the last 4 or 5 grafts (including a new bass, full neck/scroll) I have had in progress, the choice of the Neck wood, species, figure and grain has been a discussion on each and every bass. For all those hours of work and the lifetimes of use it should provide, going cheap on the wood is stupid. As Forrest Gump preached, "Stupid is as Stupid does"! That would be stupid, plain and simple. So, just one more reason you can't pin a price on 'A' Neck graft or Neck.
Ok, neck/Scroll pitch angle. How many times have you seen a Luthier CUT the Scroll to put a C-Extension on? Why did they Cut the Scroll? Well, some may have been lazy and I know that is the reason for many of them and others have just had the wrong Neck Graft pitch in their hands to work with. Advising the customer that he needs another new Graft to put an extension on doesn't sit well in the wallet for some. Guess what? I have a bass that was handled that way before I owned the bass and now I am not only paying for a new neck but the Scroll has to be expertly repaired as well. It is not the only Bass I have seen that was Cut for an Extension. So, finding a Luthier than knows his ass from his elbow in scroll and graft preparation or allowance for the future is something else to consider. I have seen several faulty graft angled scrolls in recent years and it upsets me that a good neck has to be destroyed to make the scroll pitch right once again for an extension. If an extension was already put on the incorrect pitched graft job, then the scroll also needs a repair. Finding wood to match is another problem in repairing it. If it's a dark blase varnished German bass, no biggie. How about a beautiful golden varnished English or Italian bass with a flamed maple scroll 200 years old? Who's gonna match that up and make it invisible? Can we shoot or hang the last guy that raped this Bass by either doing the graft wrong or by cutting the scroll on a bass that needed a new graft first?
Wayne, your question does not have an answer. Take YOUR bass around to 10 shops in USA and ask the prices for THAT Bass for a graft. Better yet, be a scientist. Have each one do it, over and over. Record the results and in the end see which ones did it the best, bet graft, best wood, best overall. That will cost a pretty penny but at least THEN, you will have your question answered..
