First off: Let the pictures speak, than I will ask the two or three questions I have.
Here are all the pics of the extension and scroll work. This one is the only exception. Its of the breaking -_- ![]() ![]() ![]() ![]() And the final pic of that entire side of the scroll: ![]() |
OK, sorry for the poor writing and any mispellings. It was written on the iPhone. But here are my questions:
1.) Is there any cosmetic recourse for the hole drilled in my scroll? 2.) What work (that costs money :P ) is required if I remove this extension from the bass (other than having to buy another, non-extended, string)? 3.) Would your answer to the above change if I plan on having another extension (albeit NOT mechanical) put on my bass? |
1. The hole is no big deal. You can probably use it to run the string from another type of extension, or if you don't use one, just ignore it. If it really annoys you, plug it and varnish it over.
2 + 3 - Hard to say for sure, but adding a different extension probably won't cost any more than installing that extension would on a bass that had none to begin with. All that said, I'd keep the mechanical and fix it. Just 'cuz. ![]() |
lol I think this extension has given me PTSD -no combat-related component, however.
I personally can't deal with the rattling anymore. It requires constant tweaking and then THIS happened. Just frustrating all together. |
Armed Forces solution -
Blame the ammo and put a prophylactic device on it. ![]() |
Also, what kind or brand of Extension is this and, where did you get it. Changing to a similar extension fitted to the same board will be cheaper than starting over again, I think. Do NOT worry about holes in the Scroll. They are never 100% perfect and if You change to a different extension, you will need to plug that hole and trill another. Varnish touch-up is not a big deal. Even if you put a new extension of the exact same kind, the re-fit may not work with that hole either so forget about that hole meaning anything. It is the extension and how it works that counts. Also, welding new Keys onto your fingering system might be a possibility as well. Some of these Extensions are made in China and are doomed to fail if not rebuilt including others made in Europe. These new ones are not as good as the old ones from decades ago. They call this, 'Progress'. |
Can't you just remove the metalwork, leaving a fingered extension? you'd have to come up with an E stop solution.
