Old 07-04-2007, 01:14 AM
Jeff Moote's Avatar
Default Original Flexocor & Original Flat-Chrome
Reading Ken's thread on the Flat-Chromesteel strings, and being that Flexocor ('92s) are well documented I thought I'd talk about another of Pirastro's major offerings in the way of steel ropecore strings.
As I understand it Original Flexocor (OF) and Original Flat-Chrome (OFC) are essentially the same strings, with those that meet a higher quality standard getting the OFC label. This could be entirely false, but I've yet to hear otherwise. edit: Rumor dispelled below! Nonetheless, I'm led to believe the OFC's have a bit sweeter sound - for reference they're what Jeff Bradetich uses, as far as I know.
Worth clarifying is that the Original Flat-Chromesteel is a different string from the Flat-Chromesteel just as Original Flexocor is different from Flexocor. While the Flat-Chromesteel's are bright and relatively supple under the hand per Ken's report, the OFC is a stiff heavy string with big dark tone.
Definitions out of the way, I'll share my experience. My string search has taken me from Helicore Orchestral to a mix of Flexocor (92) and Permanent strings, and now to a set of Original Flexocor. The move to Pirastro with my 92's was a great thing, as this was the first time I really liked how my bass sounded. Months later as I played on my teacher's bass I realized that pedigree of bass aside, his strings and setup were conducive to an even bigger tone - so I followed and got the Orig Flex set. They have much of the same dark rich qualities that the 92's had but with a bigger overall sound and a brighter/faster speaking top end. The G was a bit hard to tame, but with the rubber tone ring that comes with it installed it has settled nicely and works with the set. I'm fairly happy with these for orchestral playing overall, but I'm interested to know whether the OFC is worth the extra expense for a bit better tone.
I'd love to hear any experiences others have with these strings and what you think of them compared to the other standard choices.
-Jeff
Old 07-04-2007, 12:27 PM
Lightbulb Originals etc..
First off, let me start by saying that I have actually played and tested all of the Strings mentioned and even sent reports back to Pirastro on how they performed. Also, the notion about the Orig Flex and Orig FC being the same is a mis-truth. One person told me he was at the factory and the only difference between the two was the liquid dampeners the place in the strings. Well then, why are the Orig Flexs so much thicker in gauge?
For ID purposes lets use 4 string models here. The Orig Flex vs the Orig FC and the Flex 92 vs the Flat ChromSteel. Thread wise at the Ball ends I call the Origs Blue or dark blue but not purple which they are referred to. I see purple as a darker color but for now, we can say Purple or Blue. On the Flex 92s, they look purple to me but I hear Ruby and Red being used so lets say Red.
The Origs. are Blue and the OFC have Blue & White spiral.
The 92s are Red and the FCS are Red & White spiral.
Ok so far on the color IDs?
Sound and tension comparisons as well as actual Gauge;
In the Origs, the Blue Flex is a heavy Stark gauge that is actually heavier than the Flex 92 Starks! How many of you know that? Well, now all of you. The tension of the Origs are also much higher that any of the 4 mentioned including the Starks. The gauges of the Origs are also slightly thicker across with the A-string having a huge difference in size as compared to the others. The Orig FC is sweeter sounding to me than the Blues and have less tension overall! The gauges are thinner as well.
On the 92s vs the Orig Blues, the 92s seem to have a darker smoother sound especially on the G-string. When new, all the other Gs sound slightly too bright but they all mellow in time. The 92 G reg or stark, is smooth right out of the bag.
On the 92s vs the FCS, the FCS are thinner in gauge, brighter in tone and lighter in tension. The Flat Chrome Steels are an 'excellent' bowing string as far as I have tested on the two Basses, my huge Hungarian 5er and the English Theress I played recently. Why some people refer to the FCS as a hybrid String must only be because of its brighter tone and more pizz-friendly ability as compared to the 92 Reds.
Both the FCS and Orig FC are lighter tensioned strings than the solid similar colored threaded ball end colors.
Here is my chart of Tensions from heaviest to lighest;
Orig Flex.
92 Stark
Orig. FC
Flex 92 (close to the Orig FC except the E)
FCS
In Tone, I rate them as such from dark to bright when new on the Bass.
92 Stark
92s
Orig Flex
Orig FC
FCS
All of the strings listed about are great bowing strings. I Think now that Pirastro has these so that any Bass can get what it needs to sound good, bow good and feel good. I think all 3 factors are needed to enjoy your bowing Bass.
Not listed here are the Permanents which to me are mixed. The bottoms are thick and tight while the tops are thinner and maybe looser but definitely brighter sounding than the lower strings as far as a mix goes. I also heard these were made to compete with Helicors. Why bother when you have a great string. The main problem with most Basses is the 'E'.
Why the 'E'? First off, its the hardest open pitch to sound a true fundamental note (do NOT even mention the low B!..lol). Second, the E is lower at the bridge as compare to the D and A and the lower height might loosen its tension. Wanna test my theory? Put the E in the middle and move the A lower and test the sound and tension then. Third, the quality of Basses in the world are not equal. I have only seen the great English and Italian Basses mainly with true fundamental bottoms. Add a few German, Yankee and French in there as well as a few others but the average Bass out there percentage wise just doesn't have a thick true bottom!
So, what do we Bass players do? Blame it on the String company? Sell your house? No... Just understand the problem and work with it, period.
In the early 19th century when London was mainly a 3-String town it was believed that any note below their A-strings simply would not sound and this was the town making the best Basses in the world collectively at that time. Tuning to a 'G' was an option but an E? Phooey... Then came the visiting German Orchestras with their 4 and even 5 String Basses to play the Beethoven parts and Viennese waltzes. Soon after England started adding 4-string Basses to the sections but remaining a 3-string town for most of the century. Even in the early 20th century they still offered Hawkes model Basses with 3-strings.. Go figure.. the English...lol
Where was Pirastro then, huh?.. Baaaahhhhh
Old 07-04-2007, 07:52 PM
Jeff Moote's Avatar
Now that's a thorough response! I'm going to save that on my hard drive for future reference
Orig Flex.
92 Stark
Orig. FC
FCS
92 Stark
92s
Orig Flex
Orig FC
FCS
I think you're right on here - they offer many choices so that you can match strings to your bass and preferences. I guess the reason I like the OFs (solid blue thread) is because I have a heavy bow arm and prefer something I can pour the weight onto for more sound. From your experiences, it sounds like the next string for me to try might be the 92 in Stark gauge. You say they sit at the other end of things in term of dark/bright tone, but are closest in thickness. Similar under the bow I take it?
Another string that I'm curious about lately (for various reasons) is Thomastik Dominant, but that's a topic for a new thread I think...
-Jeff
Old 07-04-2007, 08:18 PM
Cool Thorough...
I have a Sticky here on Flexs and had a big Thread on TB awhile Back from which I pulled my info. Also, as I was testing strings I posted some of the results on TB. That was about 2-3 years ago.
On the Thomastics I have experience with Spiros, Superflexible (Rope Core) and Belcantos. I don't know much at all about Dominants. The Bel's are the best of the group for Bowing. Superflexibles are also Bowable as are Spiros but that depends on the Bass and the mix of strings in the Set. I have the Superflex Ext.E/C mixed with the Orch.Eurosonics. I have also used that E/C with Helicores which came on my Cornerless Bass but I removed them the same day along with the Ext and put a set of 92s on with a Stark E.
If you need the E/C for the Starks, call me as I bought the entire remaining Stock at one of the Distributors here when I heard they were discontinued. The rest of the set in Starks are still available but not the Ext. string.
On a comparison, a player took out my Bisiach to try and put on a set of Orig. Flexs. that I had in stock. 'That's the sound' he remarked when we got the Strings on. When I got the Bass back I just didn't like the tone. When I put back the old set of Flexs on it (don't recall if they were Starks or reg gauge), the darker smoother sound came back in seconds. Different strokes...
Old 05-17-2008, 08:34 AM
Phil Bishop Phil Bishop is offline
Phil Bishop is on a distinguished road
Ken, your summary of the Pirastro strings is really helpful. Could you rate the strings for pizz as well as arco? Good sustain, etc. and also a mention if any particular string (e.g. an E) in a family stands out in some way. If possible, Permanents as well?
I'm asking as I'm using Original Flat Chrome at the moment, playing about 70% orchestral 30% jazz. Next time I buy, I'll probably switch to a darker string (maybe Flex 92) and it would be really useful to get a view as to how the other strings compare to the OFC.
Old 05-17-2008, 12:30 PM
Cool Pizz?
My opinion on the Pizz quality of these Orchestra Strings depends greatly on your particular Bass itself. Put them on a German Shop Bass and they might sound dead. Put them on my Storioni and the sound like Spiros.
The OFC worked well on my Gilkes but then again so did every other string I had on that Bass which included Obligatos, OFCs, Flex 92s, Flex 92 Stark, Flex 92s with Stark E and Evah Pirazzi's. On my Martini Flexs and other Bowing strings do not Pizz as well but Obligatos do. On my Storioni everything Bows and Pizz's fantastic. My Hart has only had 92s and they Pizz ok but that's an Orchestra Bass so is just does what it's supposed to do. On the other hand, all the Basses I have that I just mentioned are Orchestra Basses as well. If the Top floats well, it Pizz's well and if the Bass is a clearer sounding Bass rather than a darker sounding Bass, it can pizz well too. Permanents have less of a quality sound than the others mentioned. The either sound bright to me or dark on the bottom when broken in. I never liked the G and D in that set for the Bow.
The best 'everything' Basses I have had included the Gilkes, the Storioni and the Dodd I used to have. The Dodd was about the best low end crunch powerhouse I had ever heard. The Storioni is similar to the Dodd but will a darker smoother silky olive oil Italian sound. Basses like this are rare but can be found. They just cost somewhere in the neighborhood of a few cars or a house depending.
One more thing. If you like the flat Chromes and need something darker, be aware that the 92s may not Pizz as well on your Bass. The Es are usually softer in that set. The OFC E might be better to leave on or mix the tops and bottoms with the 92s on the G and D.
My Gilkes has the 92s on it now but the E/C ext. string is the original/Original FC which then was called Eudoxa Steels. This was a string someone had lying around slightly used from over 20 years ago. It's so smooth and dark. It blends fairly well with the 92s and sounds even smoother.
I am doing a Pops type concert tonight and had done the 2 rehearsals with the Martini (92s Starks all the way including the E/C which the discontinued but I bought a bunch b4). The Pizz was actually too dark and deep so last night I packed up my Gilkes to use for tonight instead, It has a punchier type Pizz tone regardless of the strings used.
It's usually more of matching the String to the Bass than the player. When you hear the sound you are looking for, you will know it. Each Bass itself will not sound the same because of the string you choose. It's really what works best on that particular Bass. Some Basses are easier to fit and some harder string wise.
