#41
I suspect IF he has, he's determined that he prefers what he is currently using in his necks. ![]() About 10 years ago, I had a Wenge/Paduk combination in a custom Ibanez 6-String. Overall, the bass just didn't have the mid-range bite and the crisp highs: Just warm and muddy sounding. I was not impressed with that combination of woods on that particular model bass.
Tim Bishop |
#42
Al-Bassman-Smith |
#43
Albert, it's all about the right equipment. You have the right bass, so, depending on your playing style, set-up, strings used, and amplification and/or pre-amp, you should be able to dial in whatever you need! I've shared with you what I use and I stand by it and would put it up against anything. ![]()
Tim Bishop |
#44
Al-Bassman-Smith |
#45
I would recommend they start saving their money and spend some time reading the following thread! ![]() http://www.smithbassforums.com/showt...hp?t=21&page=2
Tim Bishop |
#46
I have found that string thru bodies have a lillte more string tention than the same bass going just through the bridge. I don't see the need with Ken's Basses. I do like the firmness of the string with a 2 piece bridge, in fact my Smith is the only single piece bridge bass that has ever been a keeper for me.
#47
Tho' it can be done after market my only change would be matching knobs to the rest of th hardwear. Tho I realize the black knobs on the wood are sort of a KS trademark in look but matching knobs to the hardwear would be the bomb. Chromes are easy to match but truly matching the gold is a bear. Yes mine still have black knobs.
Dennis Michaels www.myspace.com/dennismichaelsbass www.dennismichaels.com www.kensmithbasses.com www.eden-electronics.com Tone matters so play the best through the best. |
#48
I knew you had a reason which is why I still have the original knobs on them. I trust that what you do is with great reason. You build the perfect instruments so I just play them as you build them. Also, any one who has NEVER to to the shop it is well worth the trip to actually see these amazing craftsman at work.
#50
I don't know if this has been mentioned because I didn't read every post but why not make a separate compartment for the battery that pops open for easy access instead of hiding it under the back plate which has to be screwed off? I have two non-smith's with the feature and it came it handy one night when my batteries went dead.
#51
To implement something like this I would say make a metal access door in the metal backplate over the battery with a slotted metal latch that can be actuated using a key or screw driver. You get the convenience factor with less risk of damage from minor abuse. The plastic, spring loaded battery cover on my Dean was broken off by my guitar player when he went to put the bass on to mess around and accidentally bumped the battery compartment, causing the cover to pop open. It was then wrenched out of it's socket by his leg. That compartment was convenient, until a minor bump which is very likely to happen in normal use made a situation where the battery would fall out and dangle from the bass under normal use.. I eventually gave up and fixed it.
#52
well, a key or screw driver would be the easiest, but i'm basically talking about a rotating latch with a slot you would use something flat to turn.. in theory you could just use a finger nail..
#54
That could work
#55
I like everybody else on this forum like Ken Smith work but one thing I would change is the 2/3 gears on the 5 string models. I like the regular 3/2. No disrespect to Ken I just think the 3/2 looks better.
#56
Aren't the 2/3 gears an option? They were when I ordered my Smitty! |
#57
I'll take it either way if Ken Builds it.
I do, however, prefer the 2/3 for this reason: With this set-up/configuration, I believe the string tension is better distributed across the Peg-head, Nut, Fingerboard to bridge, thus, providing a better balance (tension-wise) across the neck. It's my opinion and I'm stickin to it. ![]()
Tim Bishop Last edited by Tim Bishop; 03-01-2008 at 01:27 AM. |
#58
Well, I'll just put this idea on the table.
Preamble: what always attracted me about Smith basses is the very peculiar body/headstock shape of the "old style" basses. The fact that they costed an arm and a leg here in Europe unluckily always kept me at... safe, drooling distance! I could not believe myself when in a forum here in Italy I could just swap my unused Warwick Corvette IV strings with what is now my 91 black Burner V!!! No money involved and voilĂ* I have my wonderful Smith "pet", too! Now, what I would propose is a reissue series (a la... Fender!) that would be done replicating exactly the old body/headstock configuration, just for the nostalgic guys like me, both on 4 and 5 strings. Maybe just a simple BSR model... Mmmmmhhhh..... difficult, uh? Last edited by Virgilio Venditti; 04-18-2008 at 10:21 AM. |
#59
Edit #2 here: This is in reference to an early post- sory I didn't identify it! Oops. Anyhow, you'll 'get it'...
Heh-heh. Yep, if it works, keep doing it. But it is kind of fun to read stuff like, "Ken shot it down" (in reference to a custom 'vanity' detail)... end of post! Low Sensibility-Divergence Tolerance! I better watch my step around here, and not mention anything about stereo wiring, or balanced-out jacks... But you can tell everybody loves their Smith bass, and has great regard for the builder and his crew. Me too, man. And someday, I'll have a BT with a Lacewood top. Someday... ![]() Edit: I like that old-style too! The BT- I at first thought it was awkward, but it grew on me pretty quick. It now reminds me of a crown- not just the headstock but the entire bass. Way cool. I have a Burner too, and also think it should re-emerge. Great bass.
"Whatever we do, it is what it is, and we do it." -The Grubs. |
#60
1). The ability to have a third pickup in the neck area. I'm sure this has been tried? Would this add some deeper tone to the perspective?
2). optional chambered cores in the body wing areas to reduce weight. I played a Sadowsky NY with a chambered body and it was an awesome improvement. I didn't notice any dif. 3). Electronics to be able to switch to an old school single coil kind of vibe. Please don't shot me! These are just some ideas for discussion! I love the ken smith I just got. Great bass. However, I still am bringing two basses to the gigs I've been playing when I need an old school vibe I bring either a 65 jazz bass or an old 4003 Ric and in addition to the KS BSR5GN for the newer fusion jazz stuff we do. |
