Old 01-12-2009, 07:08 AM
Default Is it a set up problem?
Dear friends a new double bass has arrived in our possesion. It is a Hungarian instrument, built in the 70's, fully carved, with beautiful flamed tonewood. The arco sound is excellent (strung with Evahs). The piz sound however is not so good. I strung it with Spiros Mittel and it improved a bit but it remains inferior compared with the arco sound. I experimented with the soundpost and the bridge but to no avail. Any ideas will be wellcome.
Mike
Old 02-21-2009, 01:29 PM
I was scrolling through the forum and noticed that your question had not been discussed. So here's my input:
I'd like to know what you mean by "the pizz sound is not so good". Does this mean there is a lack of bottom? Too boomy? No sustain? Too much sustain? Unfortunately, words like "good" are not specific enough. Please give us more to go on, and perhaps we can advise you. I realize English may not be your first language, but give it a try.
Pics of the bass would be helpful too. Flatback or Round? String length?
Old 02-21-2009, 02:54 PM
Lightbulb and..
So we are not confused by descriptions when you say pizz or bow, give us an example we may have heard on a recording so we know what you are trying to describe.
I have several basses that pizz well but they all sound different. 'Well' is relative to the type of bass and type of strings on 'that' bass.
Besides the pictures of the bass, give us all of its measurements.
Old 02-24-2009, 03:05 AM
Default Details...
Friends, thanks for your replies. The bass is a 3/4 roundback, with a string length of 104 cm. Talking about the piz sound i can describe it as lacking depth, lacking this "booming" which is associated with jazz music. The volume is acceptable and the sustain is good with the Spiros but... the overall feeling is not comparable with its arco sound. The arco sound (with Evahs on) is magnificent and shakes the whole place. The principal bassist int the Symphony Orchestra of Salonica played it and gave a very high appraisal for the quality of the sound. Alas, he never played jazz and he has no opinion about the pizzicato sound.
I recently ordered a soundpost with a larger diameter (21 mm) and with dense grain and i'm waiting to try it. The existing soundpost (18 mm) is not of the best quality. In my quest for the best sound in the past i had the chance to improve the piz sound in one of my basses simply changing the soundpost with a larger one, with more density in the grain. Only your invaluable help and Chuck Traeger's book can provide me any hints to work and upgrade my instruments, since there is not any respectable luthier in Greece dealing with double basses.
Thanks for yor time and i'll keep you informed for any improvements.
Old 02-24-2009, 09:06 AM
Cool well..
I think that the sound is in the wood. With a string length of 104cm (40.94") you have a small 3/4 sized bass. The pizz boom you talk about might be lacking from the thickness of the wood and just the overall size of the bass. I would assume at this point that the bass is factory made (pictures might help to guess better) and that the wood is fairly thick in both the top and back. Bowing the Evahs which have lower tension but a bigger diameter makes sense as the Spiros have greater tension and might be choking the sound a bit.
I have one bass that is on the smaller side like yours and it too lacks that depth that sounds deep and shakes the floor. It's loud and carries and has a nice boom but the size of the bass prevents itself from sounding like a larger bass that could be deeper sounding. Actually, I have 2 such basses at the moment. Both are fantastic sounding but that deep dark floor shaking boom you are looking for usually comes from a larger sized bass. Both of my basses I speak of are handmade and much older than yours. Still, they can only be what they are and they are just fine sounding like themselves. If I want a deeper bigger 'boom' sounding bass, I just go to a bigger bass. Problem solved.
Old 02-24-2009, 09:48 AM
Please check the soundpost position. It should be about the same distance in from the g-side f-hole as the bass bar is from the e-side f-hole. It should be about 12-20mm down from the bridge. It should fit really well and be just a tad snug with the strings off. A larger diameter post will likely make the bass response worse, not better. If you want to boost the bottom, move the post out toward the f-hole a bit. I fear that Ken is probably right, though you state that the arco tone is deep. How high are the strings? Is the nut cut nice and low?
Old 02-24-2009, 01:00 PM
Smile You fear?
I think it's great to be feared.. lol
Old 02-26-2009, 03:54 AM
Default Try and error...
At first let me state that i consider myself lucky to be a member in our forum, since the treasure of information i gather is invaluable. I tried the new soundpost, making a nice fitting and moving it around the ideal spot. Nothing changed and in fact the bass, as Arnold pointed, has lost some depth. I tried a soundpost with the same old diameter, but with more density in the grain. Moving it and trying it i found a place, 20 mm behind the bridge's G foot and closer towards the f hole, that seems to be the best one. The bass now gives a better piz sound and the E and A strings seem to be more resonant. Obviously, as Arnold stated in another thread, the bass bar responds better with the soundpost closer to the f hole. I think that the instrument now has reached its potential since the arco sound remains unaffected. The strings' height is 5 mm, 6 mm, 7 mm and 9 mm (G,D,A,E). Probably a larger instrument will deliver a more "booming" sound, so dear Ken, i take is as a fact.
Thank you all for your time.
Mike
