Old 02-07-2008, 12:13 PM
Lightbulb The Master and his Apprentice...
I just took some side by side pics of the Gilkes and Hart to show their similarities and differences.
Old 04-01-2009, 01:52 PM
Lightbulb The Master and his Apprentice, the Story..
Samuel Gilkes and John Hart
The written text here was taken from a combination of sources. This includes one Double Bass example in my possession from each maker as well as references from several English and International books that mention these two famous makers from the English School of the 19th century. Both S.Gilkes and J.Hart are highly regarded as the top of their class but mainly Gilkes as there is very little original work to be found by John Hart. However, individual works by Gilkes is probably rarer especially if you are talking about an actual ‘Labeled & Branded’ Double Bass which this is the only known example I have heard of.
Samuel Gilkes was first trained by Charles Harris (a relative) and later worked for William Forster III. The Forster family supplied string instruments to King George III (1760-1820) and most probably maintained the instruments for the Court and the Royal Orchestra/Band. S. Gilkes was employed by Forster from 1810 to 1819. He also opened his own shop in 1810 while still employed by Forster. His duties also included training Simon Andrew Forster, son of William III. Samuel Gilkes was born in 1787 and died 1827 (40 years old). Samuel's son William (named after Forster??) was born on 1811, just 3 years before this Bass was completed and later became a well known maker in his own right carrying out the Gilkes tradition (possibly with the help of John Hart, apprentice and assistant to Samuel as the Basses by William look similar to an early Bass by Hart). Samuel was only about 26-27 years old when this Bass was 'completed'. I say completed because the exquisite workmanship shown on this Bass along with the magnificent 7-Layer Purfling on both the Top and Back could take the best of makers several years to complete as he was employed elsewhere during it's construction.
Samuel Gilkes is noted in the book 'The British Violin' (pg. 80) and I quote, "Gilkes, however, was one of the finest Cello makers of his age; indeed, he is in the first rank of English Cello makers of any age. His sophisticated copies of Stradivari with a fine oil varnish are particularly successful."
NOTE: In the book 'History of the Violin' written in 1864 by William Sandys and Simon Andrew Forster (son of William III) both Samuel Gilkes and John Hart are included in the 'Family and School of William Forster' in chapter XXIII. This inclusion attested to by S.A. Forster, the last maker of this Family.
Note: Sometime in the late 19th century, the upper Shoulders were cut down from it's original Cello shape to make playing easier in the upper registers. Some of the original 7-layer Purfling was replaced in the cut area but this is nearly impossible to match up. I believe that the two upper Ribs may have been re-varnished when the Shoulders were cut as well as the Neck/Scroll being re-set around the same time. Only under UV light can you tell the difference in the Varnish as it is so well matched to the original Oil applied by Gilkes. Scratched in the Bass side Rib near the Neck Button there is a date reading "P.A./8.8.1884". I am told that in European writing this means "August 8th, 1884". That might be a marking from the owner at the time (P.A.?). My guess is that the Ribs were re-bent shortly before that time during the Shoulder-cut.
Although this Neck & Scroll is believed by some to be the original Gilkes Head of 1814, a few others thought it to be fine German work from the late 19th century. Since the Gear Plates did not fit all that well, it might have been made partially as a Copy of the original Gilkes Scroll that may have been damaged, destroyed or lost but also re-carved around the Volutes and the rear of the Pegbox to match the original work by Gilkes. I have recently seen a Bass by Joseph Tarr, c.1883 that made while he was working with/for James Cole who formerly was employed by William Tarr, Joseph's father. This was a Violin cornered Bass with a carved round Back which is extremely rare for a northern English maker. Tarr's Bass not only had the same kind of flamed maple on the Back and Ribs as the Gilkes but also had a nearly identical flamed Neck and Scroll with the exception of the extra carving work I had just described. I think it is safe to assume that this extremely rare Double Bass by Samuel Gilkes may have very well been Cut (shoulders) and restored in Northern England, possible by Tarr himself given the model he had made with nearly a twin Scroll/Neck to this Bass. The Gilkes being an expensive Bass for its time and a Strad Cello copy as well was most likely made for a member of English society or some level of Royalty. This Bass evidently had great care and very little use for its first 50-60 years. There are practically no cracks at all on the Top and the Back Table is nearly virgin with the exception of the Shoulder Cut and the Button replacement. The amazing wood and condition can be seen by looking at the Restoration Photos. Only the Ribs show some normal distress of a Bass nearly 200 years old.
Although the Gilkes Scroll does not look typical English style to many dealers, the book "The British Violin" from the 1998 Exhibition '400 years of Violin & Bow making in the British Isles' has a section about Samuel Gilkes (pgs.192-193) with a Cello ca.1820 which has the exact same Scroll as this Bass including the deep 'veining' in the rear to the Button. The book states; "This example is made on the Stradivari model (although some exist on the Forster 'Amati' pattern), with a particularly well-observed and crafted (if rather slender) scroll." This is evidence enough for us that Gilkes made 'slender' styled Scrolls unlike other British makers of his period when it came to the Cello and Double Bass as is witnessed here. Also, the 1805 Royal Forster Scroll made for King George III is a long and slender pattern as well. If this Scroll is a replacement, then who ever made it did a great Job.
John Hart apprenticed with Samuel Gilkes from 1820-1827. His apprenticeship ended the same year that Gilkes died. This beautiful 'Fendt-like' Double Bass has four (4) small stamps on the inside of the Back on either side of the center Crossbar upper and lower reading "J.HART" in fine lettering of the size you might see stamped on a Bow. I mention Fendt and Maggini in general only as these makers all had an individual style and only have slight similarities as far as the trained eye goes but in general do have resemblance to the average onlooker. Maggini was the apprentice and successor to Gasparo d'Salo (the first Double Bass maker in history) whose model he followed and improved on. In the early to mid 19th century, it was the favored model Double Bass made by British makers like Fendt, Kennedy and even William Gilkes, the son of Samuel and co-worker/trainee with Hart who was about 6 years older than William.
During our investigation and research on this Bass we find that John Hart signed a 'Contract of Apprenticeship' in May of 1820 in London at the age of 15 with Samuel Gilkes within one year of Gilkes leaving his employ at the shop of William Forster (1819). His apprenticeship with Gilkes is also noted in many books dating back to the 19th century. Duane Rosengard commented to me, "This is one of the greatest archaeological finds in Double Basses in decades!". This Bass also had a Business Card laminated to the lower Rib at the Block under the Varnish by "MESSRS. BIRD & SONS" (c.1890) and an inscribed message inside the lower back from a restoration by 'William Zettwitz', London 1944.
MESSRS. BIRD & SONS
56 Berwick St. 1 Door from Oxford St.
50 Double Basses on Sale from 8 to 100 guineas
The Double Bass and 40 Music Stands can be had on hire
Professional Gentlemen can have a Double Bass at a Moderate Price
(Partial Reproduction from Original Card attached by TailBlock, c.1890)
Although we have been all over the Fendt name on this Bass as that's what everyone across the globe has called it for the past 35 years or more, these 4 stamps in the Back from 'Hart' would not have been discovered if it were not under a full and diligent restoration. Arnold Schnitzer (Maker/Restorer, NY) while cleaning the dirt caked to the grain of the flamed Sycamore Back discovered these stamps accidentally as he worked with extreme dedication to do the job right. Another important English Double Bass authority believes this may well be the work or the English master John Devereux (c.1850) who was also the maker of many of the Maggini models for B.S. Fendt as well. The night I brought the Hart Bass home I received an email from London. I was told that an identical Bass to mine purchased as a genuine G.P.Maggini was once used for 30 years in the London Symphony by the former Principal Bassist at that time. They later were told that the Bass was actually British and made by William Valentine. Valentine worked for Hart and was his ‘half brother’ as well. While comparing the Scroll and FF-Hole pattern to other Basses by Valentine, Devereux, Fendt, Kennedy, Lott etc., we find that this Bass is truly original in this respect and compares to nothing we have seen before by any other British maker. Since we have conflicting opinions which is not at all unusual in this Business, we are still calling this a John Hart Bass as it is at least agreed that he either made it or had it made for his shop and bears his brand stamp, (J.HART).
Lightbulb continued..
About Hart and his Master:
Samuel Gilkes started his training at an early age with relative Charles Harris Sr. (Harris Sr., one of the best English makers of his time, London 1770-1830 and often alluded to either the "English Lupot" by Jalovec or the "English Amati' by W.Henley) and later (1810) worked for and trained further with William Forster III. Gilkes would later train John Hart. Gilkes also trained or trained with Charles Harris Jr. in the Harris shop. After Gilkes' untimely death, Harris Jr. went to work with Hart for awhile as well. W.E. Hill went to study Violin making with Charles Harris Jr. in 1835 after Harris Jrs' move to Oxford from London (1795-1828). Also, Olde Bird (Bird & Son) personally introduced Bow maker Samuel Allen to W.E. Hill. Bird was once in possession of this Bass as noted by his card on the lower Rib. He is also an indirect link between Hart, Hill, Gilkes and Harris as they are all connected to either this Bass or the Hart/Hill 'feud' in one way or another as the Harts and the Hills were in stiff competition with each other. The Harts were makers, restorers and dealers. John Hart was the best followed by his son George and Geo.II. Later, the Harts would turn to mainly dealing with John Hart employing his ‘half brother’ William Valentine who made most of the Hart Basses and some possibly for Fendt as well. Hart & Sons, the later firm also employed the Voller Bros. and others in and out of their shop for Violin making. The Harts became the main dealers and connoisseurs in London of Italian Violins in their time as seen in many books by the phrase 'according to Hart, etc'. This can be seen in many books especially those of English writers but as far as John Hart himself being a maker, his work has rarely been seen.
I will update this important page of English Violin/Bass history as things develop. For now, I am calling this Bass the individual work of young John Hart made just after his apprenticeship with Samuel Gilkes and not Bernhard Fendt Sr. as that's where the evidence is pointing. This Bass dates mainly before we see Basses individually from Lott Sr., Kennedy, William Gilkes (who trained with his father Samuel along with Hart) and even Bernard Simon Fendt as they all worked for other makers in the first part of their lives. It is reasonable to speculate that William Gilkes who was about 8-9 years old when John Hart began his apprenticeship may have worked with Hart after the death of his father. In 1827 when S.Gilkes died William was still only 16 years old. Hart having trained and worked with his father in the same shop for 7 1/2 years by then was possibly like an older brother of William. A Double Bass by William Gilkes that I know of c.1840 has some similar flavors to it when comparing it to this early work of Hart.
According to Thwaites of London, the work of John Hart, what little has been seen and confirmed ranks equally amongst the likes of Lott and Fendt and can stand along side the 'best' of the London Double Bass Makers. With the exception of this Bass here, most if not all of these other Hart Basses are more likely the work of William Valentine, his ‘half brother’.
Old 04-02-2009, 10:53 AM
thanks ken,
posts like these make this forum so valuable.
Old 04-02-2009, 11:00 AM
Thumbs up yes..
thanks ken,
And my fingers sore.. lol
By the way, William Gilkes is mentioned several times in the Will, not just twice. He was appointed as one of the Trustees of his estate or something like that and was paid a fee for his service as mentioned in the Will. This shows that although not a blood relative, he trusted him with his most personal matters.
Old 08-07-2009, 11:16 AM
Thumbs up interesting note..
This may sound strange but a few years ago from a genealogy website I corresponded via email with a living descendant of Samuel and William Gilkes.
A few months ago I was contacted by a living relative/descendant of John Hart while searching his roots.
A few days ago I was contacted by someone about the Forster Royal George basses for a personal quest in connection with an English Museum. That persons middle/maiden name was of course Forster, what else!
All I need now is a relative of Charles Harris who first trained Gilkes and I can wrap up this whole Forster School English family business.. lol
Old 08-07-2009, 12:16 PM
Thumbs up Forster!
some weeks ago i played a (so-called) forster bass with the royal coat of arms on the back of the scroll.
that was a really great bass, and in a healthy state, no bad cracks at all, very huge sound.(but a little expensive imho)
but irrc the coat of arms was different from the ones i know from mr. houskas website (the only place i´ve seen that scrolls):
did forster made several different basses from this kind?
do you know anything of the bass that belongs to the above scroll?
Old 08-07-2009, 02:11 PM
Cool humm
Ok, is that the Scroll pictured from Houska? Where did you play the Forster? What size and model/shape was the bass made in? Price? PM me if it's private but I am curious to know. Forster made only 3 for the King and I believe they were each a different size. One that sold here years back was a Chamber size and one noted in the book was full sized to out do the Italians as the King requested. That's all I know as I have never seen any of them in person. One I did see in New York I believe was made by Young Forster when Gilkes worked there. The dealer swears it's Old Forster but in Simon's book, he describes that model bass as they made 5 or 6 for lending out. Cello shape all with second class making. The one I know is dark varnish, big ugly scroll and scratched purfling on both plates.
There is a claim mentioned by Simon Andrew Forster that as a young man or boy, Gilkes met Old Forster who shared his secret varnish recipe with him. Simon Andrew goes on to discredit this theory because Forster II (Snr. of London) died in 1808. Gilkes left the Harris shop and started in the Forster Shop (young Forster III, 2nd of London, the Grandfather William I having worked only in Brampton) in 1810, 2 years after the death of Snr. Gilkes however was already working in London with Harris for several years before 1808 and could have easily met the old master by introduction as only 2 years or less later, he was hired by his son, William III.
Now, the bad blood between Gilkes and Simon Andrew ran deep deep red. Gilkes was appointed teacher of Simon Andrew, the son of William III. William IV, Simon's brother and son of III worked side by side with Gilkes as noted in the family records of instruments they made together. Simon Andrew wrote in his book some decades later how Samuel Gilkes would not teach him all that he knew and because of this his progress as a maker was hindered. Simon also learned a bit from his older brother William IV and his father known as Young Forster, William III. Some books mix up these 2s and 3s because the first William never worked in London so the first William to hit town was the 2nd. Adam Whone in his book about the Wither's shop makes this error calling them 1 and 2 instead of 2 and 3. I emailed him about it but ofcourse he didn't respond to my correction.
I think whether true and false about any hint of relationship between Samuel Gilkes and William Forster II (Old Forster) is strongly disputed due to this bitter taste which sounds to me like self inflicted. Simon Andrew was a talented maker to a degree but not up to the strengths to match any of the family named William. In the Simon Andrew book he also mantions having made 5 basses in his own shop and numbers them as well. Number 4 recently came up for sale here in the States. One potential buyer asked my advice and sent me some pictures. Before I go on, let me say that in the book he states that due to the large size of the basses, he had to solicit some outside help. I don't recall the exact quote word for word. Anyhow, I looked at the pictures of the bass and then turned my head to look at a J.F.Lott sitting here behind my desk and then I remembered something. One of our distinguished bass authorites had mentoned to me earlier that he had seen two S.A. Forster basses and they were the work of none other than J.F.Lott. The Varnish and Scrolls however possibly not. The bass #4 was a Lott bass made for S.A.Forster as Lott also worked for the trade.
So, this English stuff is quite interesting to me especially when you can read the books and look at the instruments side by side. Regardless of Simon Andrew's whining about his studies with Gilkes, he gives high marks to both Samuel and his only true non related apprentice John Hart.
On the Gilkes/Forster cloud of information, the son Young Forster aka William III I am sure knew the varnish mixture of the falimy whom Gilkes worked for. My Bass of 1814 looks to have taked years to make by the details alone. Gilkes started his own shop the same year he took employment with Forster. Why 2 jobs? Well this was common back then and often the 2nd job was not in music or at least in making fiddles. I believe the motivation is from several factors. One, he trained with Harris who was considered a great maker but stayed out of the limelight working often for the trade. This first training must have inspired Gilkes to open his own shop after his apprenticeship. Two, his son also named William (Gilkes) was born in 1811 so starting a family and having that added expense required him to raise his income abilities. Three, the job in the Forster shop which lasted for 10 years or so gave financial security for him and his family. Having his own shop as well I am sure helped to adjust his hours as needed if I may speculate. The Gilkes bass in my posession shows details and varnish combined not seen before on any bass English or Italian. The varnish which seems all original appears to be quite durable yet flexible. Looking close, real close you can see it is totally crackled on the Top. This I believe is that Amber Varnish they all talk about with real fossle added to the mix for lastisity. The Purfling is paper thin (or actual paper) 7-layer but within normal diameter as used for Violins. The Back is totally intact from the shoulder cut on down as well as the purfled Diamond loop under the Button. The Top has been worn on most of its edges with maybe less than half the original Purfling remaining.
This talent alone between the Varnish and Purfling seems to be beyond the grasp of most any maker, Forster or other so Simon need not be so jealous. Talent is not taught in my opinion. George Hart, son of John states that his fathers master (S.Gilkes) in the regards to the best work seen on some of his instruments was more of a labor of love.
A few years ago a top English dealer paid me a visit here. I showed him the Gilkes and handed him a flashlight and magnifier glass to look at the Purflied diamond and corners on the Back. He remarked something to the effect (with eyes wide), "I have never seen anything like this in my life" in a very complimentive tone, very.
The English have made some amazing instruments in the 18th and 19th centuries. They deserve the highest marks along side the best Italians where and when deserved.
Old 08-07-2009, 02:42 PM
wow, long post...
i send you a pm
edit:
yes
