Old 04-12-2010, 03:02 AM
Will Kelly's Avatar
Will Kelly Will Kelly is offline
Will Kelly is on a distinguished road
Default A Question...
Is it possible to have fingerboard dots inlayed after the fact?
I am looking at some used KS basses and unfortunately none of them have top dots.
Old 04-12-2010, 05:05 AM
Thumbs up Yep....
Yep, it is. If you are going to do it locally, just make sure you find someone qualified, otherwise, send it to Ken.
Old 04-12-2010, 05:06 AM
Question Also....
Also, have you considered side dots as another option?
Old 04-12-2010, 10:59 AM
Lightbulb yes..
It is 3x the amount of work to do them after IF neatness is desired. We do them so it looks like it was originally made that way.
Old 04-12-2010, 11:00 AM
Exclamation find someone?
Basses we see done out in the field often look hacked. It is not as easy as one would think with the Frets in.
Old 04-12-2010, 11:04 AM
Lightbulb side dots?
Tim, every bass we have made in history since day one has side dots. We have never made one without them that I can remember.
We have used REAL Mother of Pearl from the beginning, NOT plastic like the other companies use. We use 3mm sized dots which are about 1/8" in size by comparison. These Pearl dots cost about 98% the price of the 8mm dots we use on top. It's a labor cost more than the material when comparing the prices.
Old 04-14-2010, 11:13 PM
Hey Will,
Just a thought here but, you will most likely never look at the dots on the fretboard. If you are the type of player which frequently looks at the neck while playing, you will give most of your attention to the side dots. I've often wondered why there are dots on the fretboard since only the audience can see it.
Later, Kirk
Old 04-20-2010, 12:39 PM
Will Kelly's Avatar
Hey Kirk
In answer to that...
I use the dots all the time on the fingerboard. On a four string bass, it doesnt matter to me if they are there or not. On a five or six, I need them. Two reasons: It makes big position shifts on the fingerboard easier for me, and second, my eyes are failing me. When I look at the fingerboard of a multi-string bass I often see double the number of strings. The dots give me a good spatial reference with some depth perception.
Old 04-22-2010, 11:32 PM
Hey Will,
I respect and can completely understand your perspective and other considerations. I'm in a similar position! At my age, almost 66, and on a dimly lit stage, I find the side dots a bid difficult to see when I need them! My point is that it can be difficult to crank the neck around to look at the fingerboard, instead of the side dots, while watching the guitarist for cues and keeping the other eye on the new drummer to give him the same cues! SHEEESH!!!! All the pressure!!!!!!
Later, Kirk
