Old 10-16-2010, 12:26 PM
Default Belgian and French
Generally I have seen most basses fitted with French style bridges but occasionally do see Belgium. What is the "difference" (if there is any) and why would someone opt for one or the other? (Just curious)
To me it looks like French bridges have slightly wider feet whereas the Belgian might be taller in height? Please correct me if I'm wrong (it's probably a generalization).
Old 10-16-2010, 12:37 PM
A Bass needs the size it needs. I don't know all these differences myself. I just know when the bridge is right or wrong for a bass. In general.
Old 10-16-2010, 01:34 PM
A Belgian-style bridge has tall feet and a small body. The low mass of the upper part of the bridge is thought to filter out less high frequencies than a typical French-style bridge. Belgian-style bridges are preferred by some soloists, because the sound tends to be more brilliant. Bridge width is another matter, determined mainly by the position of the bass bar and distance between f-holes.
Old 10-16-2010, 02:17 PM
Thank you Arnold, that's really fascinating. Also the hearts sometimes look different as well.
Old 10-16-2010, 06:30 PM
There's also a difference in the shape of the wing area, ie., the spot where an Underwood pickup goes. I don't know which is which, though.
Old 10-17-2010, 06:52 AM
Do we assume this is considering bridges of the same overall mass, or is there a tendency for one to be heavier than the other in the same size?
Old 10-17-2010, 10:07 AM
I don't know. I've never had the occasion to inspect two bridges made for the same bass; one French, the other Belgian, and then to weigh them.
Old 10-17-2010, 10:30 AM
In a Belgian bridge, an Underwood pickup doesn't go.
Not very well, anyway ... the bottom of the wing is curved.
Old 10-17-2010, 11:35 AM
Thanks, Matthew-now I know which is which.
Old 10-18-2010, 08:42 PM
Makes sense. Now that I think about it some more, I suppose that style doesn't make any difference in overall mass, since either could likely be trimmed out to match the other. So just a matter of where on the bridge the mass is situated, although I'd speculate that the length (flexibility) of the legs is just as much a part of it...
