#161
![]() ![]() On a more friendly note, the new pics are up now and we left the old page stand as well so people can look at both and compare if they wish; http://www.kensmithbasses.com/doublebasses/storioni/ |
#162
Lovely looking bass!
Why did you put the little 'wolf tone' thing on the A string? Last edited by Richard Prowse; 05-14-2011 at 09:00 PM. |
#163
I did an Orchestra concert and Chamber Gig without the eliminator and had no problem at all. Playing alone in the room though I can hear everything. When I stop playing, all of the other basses in the rack are making noise. This monster vibrates everything from the floor to the ceiling and the walls as well as everything in-between. I had Original Flat Chromes on it first and didn't like them on this bass. Then I put some played-in Belcantos on and the bass improved 100%. Then I tried the Passione's and wow, the bass loves them. I used to use Flex 92s with a Stark 92E. The Bass loved those as well. I have yet to try 92s on the Bass post restoration but the Passione's are doing just fine. I also have a set of Jargar medium's coming in but until the Passione's wear out or wear out their welcome, the Jargar's will sit in wait. I find that this bass prefers lighter than heavier strings. I have to listed to what she tells me! ![]() |
#164
Well Ken, my Ab notes on E & A are a problem. Should I put my little screw on device back on? Say, on the A string?
#165
Try it and also try on the D. The Ab wolf is what I have now slightly. Much less in the way than the A natural.
#166
Ken,
You must hold on to that bass at least until August! I am going to be in the North East early to mid July and need to play that one. ![]() We are starting to plan the itinerary now, so I will be in touch to see when we could drop by the shop and take a test drive. Best, Brian |
#167
I agree with Brian's sentiment. If the bass is that good, why would you want to get rid of it - life is too short.
Hey, I've just put that little screw gadget on my A string and the Ab seems clear now on that string! Last edited by Richard Prowse; 05-14-2011 at 09:02 PM. |
#169
Also, I have other basses I like playing as well. One other bass in particular that I have in restoration is a sweet sounding old Italian that I am waiting to play and see which I like better. Besides playing and collecting, these are basses I sell. I would prefer if sold, the Storioni would go to a player that I look up to and admire. I play it in the shop just about every day. Until Orchestra season starts up in the Fall, I have no where to take it. The concerts I have in the Spring and Summer are just not optimum situations for a bass like this unless it's the only bass I have. |
#170
Ken,
if you're happy, I'm happy. |
#171
Ken, just a little question about that little wolf tone device on your A string.
I put one on my A string (same place as yours) and it got rid of my Ab wolf tones - then I discovered that G, up on the A string, had a wolf tone. I tried the little chap on the D string, but it still effected the G. I've taken it off because it is easier to live with a funny Ab. Have you had much experience with wolf tones? Is there any logic behind how the little device works? |
#172
You can find a wolf on any instrument no matter how subtle but it's there. |
#173
I made a new Thread for one of my Cornerless Basses that has Corners but outside Scalloped Blocks. Thread here.
I have also seen several basses that had single Guitar Ribs but the Top and back had Corners. On the Ribs were glued on external corners across the Ribs. Only on of these I have seen in person. Inside, it looks totally Cornerless Guitar style. Here are a few borrowed pictures. I have seen a few others as well with similar external Blocks. One attributed to Testore, one to Montagnana and one just Northern Italy. None of them resembled each other in the actual style of the bass so I would say 4 different makers. So whether Scalloped blocks externally or full blocks, there is more then one method of making a Cornerless Bass internally or rather, a Guitar model Bass. To date, I have played each of the 3 styles, two of which I currently own. |
#175
I'm a bit confused as to the scalloped blocks. Are they what appear to be (for my novice eyes) rounded violin corners? That's how I'm perceiving them. Could they have been added later, or where they build with the bass?
Either ways, very nice looking basses. How do I go about getting in your will, Ken? Edit: After looking closer at the pictures of your Scallopini, I see it a bit more clearly now. That is some impressive woodwork. Are the purely for beauty, or do the have a function? Perhaps they make the bass easier to lie down? |
#176
The first time I saw pictures of this bass I had my own doubts as the blocks looked detached from the actual bass in design. When I finally saw the bass in person it all came together in seconds. The Blocks are original to the bass. Without them, the corners would break off having no support under them. When Robbie (the Restorer) first saw the bass, he thought they were ingenious (or some comment like that Arnold mentioned to me). Upon closer examination, the 'fluting' of the Scallops in the Blocks looked just like the Neck Button carving. The same hand, without a doubt in my mind. Internally, this bass looks a bit like a large elongated guitar. Externally, it looks like a violin model bass. The Scalloped blocks and the hooked 'tooth'-like corners leads me to believe it was a maker near a sea coast. That is why I suspect Genoa. My Candi bass has a carved out Crab in the Gear handles. I have been told these are from hotel keys and I have seen the same handles on other Italian gears as well. So Sea-like ornamentations on one Genovese bass leads me to believe it was a sign of the culture. Having the Scalloped Blocks, hooked like Corners (Shark tooth?), a Guitar/Violin maker in the period of this Bass named Lodivico and an actual similar shaped bass model almost as old (but more refined in its Violin style) seen with the inscription Lod Parisini 1813 (Bologna) all seems connected within this bass. I might be totally wrong on the maker's name here but the other bass with the same shape, size and angled sloped shouldered round back looks like a match to me. I have never seen a bass like this before, all things considered. Look at the Scroll pics. This maker made this Bass. Similar carving to the Blocks but the Violin skills shine the brightest in the Head and also the beautiful Fs. My bass cover is in the car. In a few hours I will hit the road to get this beauty. More to come on this... ![]() |
#177
Some recent shots now on FaceBook
#178
#179
I love the nickless FFs.
