I would like change my 705 Pick ups
Any suggestion? What s the defference in sound between a Seymour and a Bartolini I heard that the bartos make no more "clacking" noise when slapping on the B string. Correct?? Thanks |
Tim Bishop |
Ksd 705
Why would you want to change out the stock P/U's? ![]()
Tim Bishop |
When slapping the Bstring, i have a nasty "plop"
And Ive heard thet the reason is the "bad" PU And the "output"level is a little bit low Thx |
Not necessarily. I'm not buying that it is a bad P/U. Here's a couple possibilities why you may have this issue: 1. Maybe it is related to your technique - Where on the bass are you slapping the strings and how aggressive are you when slapping? 2. Maybe the P/U's are adjusted to close to the strings. - Depending on what you discover from 1 above, maybe you need to adjust the P/U's accordingly. 3. Depending on what you discover from 1 and 2 above, maybe you need to adjust your output gain (if applicable) on your bass to better match that to your amp. Consider the above before you throw your money away! ![]()
Tim Bishop |
