Old 09-05-2007, 04:06 PM
alec derian alec derian is offline
alec derian is on a distinguished road
Originally Posted by Bob Branstetter View Post
I did not like the AMT stock mounting system that clamps to the bouts. With that setup, you have to attach it for the job and then unattach it when you put on your case. A real pain! I designed the tailpiece mount so that the cord is detachable, but I leave the mic on my bass at all times. .
Hi Bob,
My AMT should be arriving in the mail very soon, and I would love to know exactly how you removed it from the standard mounting systems it comes with and perhaps some more about how you attached it to your Double Bass. Is it pretty easy? Maybe this will all be self-evident when I receive the mic. In any case, your experience would be much appreciated.
Old 09-08-2007, 01:11 AM
The mount I'm using now is the second design I've done. I made the first one from spruce. It was OK, but I really wanted one that I could adjust the angle of the mic coming out of the tailpiece. My current design was made from a short length of 2" Aluminum angle stock. The mic tube is attached with the same small plastic pipe clamps that are used to attach the jack on Gage Realist pickups. They are available in most any hardware store.
Before you start, keep in mind that this modification will void your AMT warranty. It's a good idea to use the mic a while with the factory clamp so that you can be absolutely sure that you have found the best location for the mic head. In my case that spot was located directly under the end of the fingerboard and on the center seam. I keep the mic less than 1/8" from the surface. While this may seem to be an unlikely place for the mic, it enables me to get a great sound and much more usable volume before getting into feedback. I've found that the area around the ff holes is one of the worst places for the mic as it gets a boomy sound and is more prone to feedback. This may not be the best spot for you, so experiment on jobs since it will always sound great in your living room.
Removing the AMT body clamp from the tube and goose-neck can be a challenge. Thanks to Marty Paglione (the designer of the mic) at AMT, I know that you must heat all of the tiny set screws with an alcohol lamp before removing them. If they are not well heated, the threads may strip when you try to remove them because they are installed with Loctite so they won't vibrate loose. As I remember, there are 3 different size set screws. I had to go to a machine supply shop to find the smallest Allen wrench since it is smaller than any of the "standard" sizes. I can look up the sizes for you if you need to know. Once the set screws are removed, you can slide off the clamp portion. If you aren't real good a soldering small components, having a friend who is good at it will make the job a lot easier. You must cut the cable coming out of the tube housing and install a Switchcraft EN3 plug on the mount if you wish to keep the wiring to the preamp the same as it is stock. Of course you will need a EN3 jack for the cord that you cut off. They are available from several mail order electronic supply houses. You could substitute a Mini XLR plug and jack for the EN3. That will do the same job and are probably be a little more sturdy than the plastic EN3 fittings.
I attached the adaptor to the back side of my tailpiece with cap screws (Allen head). By using an Allen Wrench, I can loosen or tighten the screws (after initial installation) without removing the tailpiece again. I tapped the threads into the tailpiece so that I could partially loosen them to remove the mic mount and then reattach it as many times as I might need in the future. As it turned out, it has been permanently attached to the tailpiece for the last two years.
I'm sure there are other things that I left out, but this should give you a pretty good idea of what my mount is all about. Feel free to PM me if you have any specific questions. FWIW, I also wrote about the mount over on the TalkBass forum.
ID:	369  Click image for larger version
ID:	370  Click image for larger version
Old 09-09-2007, 07:00 PM
David Powell's Avatar
Default Unusual Observation?
At a recent rehearsal using the DPA 4021 with the AI Coda, I observed a curious behavior concerning feedback or the lack thereof. I noted earlier that I could run the channel (notch filter on) with the gain at the 9:00 o'clock position and the master at 12:00 without feedback. What I observed at a recent rehearsal (concrete floor) and confirmed at a a gig today (carpeted plywood) is that I can boost the master gain well beyond 12:00 o'clock and still not get feedback while attempting to increase the channel gain beyond the 9:00 o'clock position results in immediate feedback.
This seems odd to me, but in any case, boosting the master now allows me to get very loud with the mic and still no hint of feedback or boomy resonance. Odd, but a welcome discovery. I'm guessing the behavior is the same with other mics as well? Has anyone else experienced this?
Old 09-11-2007, 12:16 AM
I've never tried running mine that way since I get plenty of volume with my S25B by leaving the master at "12 O'clock" and I frequently have the input level up around 11. Of course knob positions aren't really a good measure of the actual (db) output. The sensitivity of the input device (mic or pickup) can make all the difference in the world.
The AI Series III Coda manual says (on pg. 3):
"The input level controls the level of the signal at the input stage of the preamp. The master volume controls the output of the preamp (at the input of the power amp). Set the master control at "12 O'clock" and the input level at zero. The input level should then be used to control the overall output of the unit. The two controls are provided to allow independent control of the "house" volume and "stage" volume when the unit is used as a stage monitor with a connection to a house PA."
It would be interesting to see how your system responds without the notch filter on. I would assume that the notch filter would be on the preamp.
Old 09-11-2007, 12:47 PM
Question Mics..
I played last Saturday night in a club and was the 3rd gig I used my old 1970s AKG Mic wrapped in foam in the bridge legs. Would one of these new thingys you guys are talking about be better in any way or are they just smaller? I am asking because I am a bit of an old schooler and have not tried anything new other than the Shadow Underwood copy which I also like. I use that usually but in a small club or recording with an expensive English or Italian Bass that the Bridge doesn't want to be altered I have just used the Mic where volume wasn't an issue.
Old 09-11-2007, 02:07 PM
To Bob B.'s:
Those instructions are why I had not previously tried to go beyond 12:00 on the master. In fact I can't really explain why I finally decided to push it and see what happened, just a sudden impulse I guess. The notch is definitely channel specific so it is applied to the pre-amp gain. The phase reversal function is what it is doing that is possibly the most important. I might call Rick Jones and see if he can explain the behavior. Anyway I'm kind of happy to discover that I can push it up a bit more.
Responding to Ken:
If we are getting better results from smaller mics, it is probably more because we are using them with AI amps. The notch filter and phase reversal features are critical feedback reduction measures that make a real difference. The only thing that is better about a smaller mic is that it can be mounted on the bass closer the wood, very close in fact. This gives the mic a stronger input and the large area of the bass in close proximity helps sheild the mic. Other than that, there is no reason I can think of that a smaller mic should or does work better. If you can get the big one right up on the bass, I would think it would be very similar with an AI amp.
It still feeds back before the piezo!!
Old 09-11-2007, 03:57 PM
Lightbulb ok.. ok..but...
To Bob B.'s:
Responding to Ken:
Ok but, I only use the AKG in a studio setting or on a smallish Trio or Duo gig where I just need a little more volume for audibility and pitch. I think the Basses I use in those settings sound fine acoustically but they are used to hearing more bass these days. The first time I did this was at a trio gig and Arnold had just finished the restoration on my Gilkes. He told me the Bass needed to be played a lot to break in again. I told him I had a trio gig and needed to cut the Bridge tabs for the Pickup. "You're gonna cut the Bridge I made for the Gilkes?" he screamed at me..lol.. "Ok ok.. I'll use a Mic".. I said to him. So, that's how I got into using the Mic again, out of fear..lol. It was in a bag of stuff in my basement that has been stored away since I retired from Playing in the late '70s. It still worked and sounds great every time I use it. In one place I play, they have an Amp there so I just use whatever Amp is convenient.
Old 09-11-2007, 05:03 PM
To Bob B.'s:
Responding to Ken:
I agree with some of this and have a different slant on the rest. I have the same AI Coda combo amp that David has. I think at least part of the reason that we get more mic volume before feedback is the down firing design of the AI combo amps. I only recently started using the notch filter and was still able to get plenty of volume (without the notch) in most situations without feedback.
One difference with the AMT S25B mic is that it was designed and has a preamp that is designed just for doublebass, and it has a built-in shock mount for the mic head. That has to be one of the reasons it works well. The goose neck on the AMT mic allows me to have the mic just barely not touching the top, so as David said it gets more of the wood sound. As I mentioned in a previous post, I used mics wrapped in foam rubber and stuffed in the bridge years ago myself. However, anytime you do that, you have to be deadening the top and bridge vibrations a little (at least).
Old 09-11-2007, 05:11 PM
Cool deadening the top..??
Well Bob, anything that touches the Bass including a rag under the tailpiece, a bow quiver or any other mounted pickup can deaden something somehow. Every orchestra player that comes here to try out a Bass pulls out the rag I keep under the TP (for wiping the strings) as they claim it dampens the sound.
By the way, doesn't the bass touch our body when we play? Are we deadening it as well? If that is true, I deaden it now more so that I did 30 years ago..lol
The 3 Basses I have used the Mic on recently were as follows; The Gilkes with a Trio, the Loveri in the Studio and the Riccardi Storioni with a Duo. I don't think any tone loss was noticeable on those Basses as the have a bit of sound to spare..
Old 09-11-2007, 10:06 PM
That's true to a certain extent, but it is the Top that generates most of sound. I don't touch the top when I'm playing - do you? I don't know if you are deaden it more today than you did 30 years ago, but it's pretty certain that your ears aren't as good as they were 30 years ago. I know mine aren't, so I can't afford to throw away any sound when there is a way to prevent it.
Old 09-12-2007, 02:52 AM
Cool 30 yrs ago..
I agree with you on the Top thing to a point but when listening to Basses I often hear more sound on some of them from the Back than from the Top standing close to the Bass.
I think that some Basses can be dampened more easily as they may have less sound to put out to begin with. On the other hand, many of the Basses I have are so powerful in comparison, I rarely hear the other Basses around me in the section. In that case, even if objects do dampen the Bass, it is no great loss to be noticed.
Old 09-12-2007, 10:02 AM
I suppose it might be worth mentioning that since I have improved the amplification method for my double bass, I think the only use for something like a EUB at this point would be for airline travel. I suppose it may take a while to confirm that, perhaps a few more outdoor shows. I have another one coming up at the end of the month. And even the best amp and mic combination is a good deal less $$ than a Clevinger and I get to use the same DB.
I have to agree with Ken as far as a great deal of sound coming from the back of the bass. In a standing situation I can really feel the back of the bass reverberating rather strongly while I play. The effect I observed and described in another thread which involves "early room reflections" while playing with my back to a wall also suggests that the back of the bass contributes substantially to the sound. I have often thought that my body dampens the sound more than anything else could although probably not as much as Ken's.
However, it is plausible that anything that dampens the bridge, the strings, or the afterlengths could have a greater effect because these precede the body vibrating and something that dampens these would decrease the energy flowing to the body of the bass, before it gets there.
It would be interesting to put a mic on the back of the bass and see how much signal we might get and what the differences are. I know very careful mic'ing of drums in the studio often involves two mics to produce something closer to the live sound of the drum. It might be interesting to mic a bass from in front and in back. Hopefully there wouldn't be any phase cancellation.
Old 09-12-2007, 10:37 AM
Cool Dampening and Mic'ing
Yo, it's all in the technique.
It would be interesting to put a mic on the back of the bass and see how much signal we might get and what the differences are. It might be interesting to mic a bass from in front and in back. Hopefully there wouldn't be any phase cancellation.
I think I have tried a Mic in the Back at one time and it was a boomier, less direct type of sound. I don't know if any phase cancellation would happen and/or why it would or would not. It would probably just be the same as if the Bass is just louder as far as any Wolfs or Note Cancellations.
Old 09-12-2007, 11:32 AM
Default Different mics, different positions
I was involved in a bass mikng technique class for live sound engineering students a few years ago as the demonstrator. I don't recall any real details about the mics used, but the instructor hung one of the mics from behind my bass, over the scroll, and got a wonderful, natural sound through the system. I had never seen that technique used before or since, but I imagine that unless you were playing solo, that mic would pick up every thing else on stage.
Old 09-12-2007, 11:56 AM
Actually, I was thinking of the muting effect from the mass of the mic & foam rather than the amount of sound radiated by the instrument. However, measuring the relative amount of sound radiated from the back, sides and top is quite easy. A simple $30 Radio Shack ****og volume meter works quite nicely. That's what I use to determine the A0 frequency inside the bass. I bought it originally for setting up my home surround sound system.
Old 09-12-2007, 12:05 PM
Cool okkkk
Bob, you can ABC my Basses anytime you like. I don't personally buy into that theory mainly because I am clueless about it. Changing strings for me has made more differences than just about any type of adjustments have.
Maybe it also depends on the grade of Bass too. You think?
Old 09-12-2007, 10:42 PM
Default No Theory Here
What theory? That a Radio Shack volume meter will allow you to determine the relative amount of sound coming from the back, front, ribs or any other part of your bass? The only thing I said was the I use it (the Radio Shack ****og volume meter) to determine the A0 frequency (by measuring the volume) inside the bass. No theory here either, just the fact that I find this inexpensive volume meter quite useful for lots of things. It's also a fact, not theory, that I used it to setup my home surround system, which I might add sounded quite good after making the adjustments to the individual spreaker channels.
I assume that you were jumping to a conclusion that this had something to do with A0-B0 matching. No, I gave up trying to convice you of the merits of that and other well documented proceedures that I use a long time ago.
Old 09-12-2007, 11:56 PM
Cool oops..
What theory? That a Radio Shack volume meter will allow you to determine the relative amount of sound coming from the back, front, ribs or any other part of your bass? The only thing I said was the I use it (the Radio Shack ****og volume meter) to determine the A0 frequency (by measuring the volume) inside the bass. No theory here either, just the fact that I find this inexpensive volume meter quite useful for lots of things. It's also a fact, not theory, that I used it to setup my home surround system, which I might add sounded quite good after making the adjustments to the individual speaker channels.
I assume that you were jumping to a conclusion that this had something to do with A0-B0 matching. No, I gave up trying to convince you of the merits of that and other well documented procedures that I use a long time ago.
Ok Bob, sry.. My bad.. I mis-read your Post. For judging the volume of the Top or Back or whatever, I just use my ears. I don't know what measuring them could do if that's how the Bass just is. On the AO/BO thing, I'm more of a 'see it' kinda guy than a 'read about it' person. I need to experience things for myself before I tinker with things. The A-B thing is for another thread some place else on the Forum so we will leave it at that. I know we did this over on TB before but I would welcome the open type discussion of it if you are willing to start it up again over on the Luthiers section here.
Old 09-13-2007, 04:49 PM
Thanks for the offer on A0-B0 Ken, but I got my fill of discussing it over on the TalkBass Forum. It was unfortunate that none of the luthiers over there were unwilling to seriously look into it and try it for themselves, preferring to declare it bogus and putting me in an adversary role defending the concept. I can only say that I have used the process successfully on many basses and believe that it is tool that should be in every luthier's shop. After going through that rather unpleasant experience on TalkBass, I made a personal decision that I will not discuss it any longer on any forum or Internet discussion group. However, I am always available to answer legitimate questions from anyone who is truly interested in trying A0-B0 matching by email or PM. I have sent out many copies of my 1996 Michigan Violin Makers Assn Paper on A0-B0 matching in basses to interested individuals as email attachments. The same offer also applies to questions about the Vibration DeDamping process which we briefly touched on in an earlier thread on this forum.
Old 09-13-2007, 05:05 PM
Thumbs up well...
Ok, on that note, I would like to have one of each for my reading and files. I am sure there is something to gain there if one makes the effort. I on the other hand have been fortunate enough to choose Basses that need very little help other then the obvious repairs needed. Maybe I have done some matching on my own but didn't know I was doing it. I have set-up and improved quite a few basses in my time going by just feel. It would be good to see this in print. Maybe some others here would try this and discuss their results and that way we could have an A/B forum that you might, just might visit on occasion and give a shout once in a while.. That would be nice.
Currently Active Users Viewing This Thread: 26 (0 members and 26 guests)
