Old 05-04-2009, 10:07 AM
Brenton Carter Brenton Carter is offline
Brenton Carter is on a distinguished road
Default Humidifier recommendation
i'm shopping for a humidifier. this isn't brain surgery but i wanted to see what luthiers are using in their shops. my apartment will be about 700 sq ft so it probably wouldn't need a huge one. what do you think? oh, and i'm looking for the best value, also. thanks!
Old 05-04-2009, 11:13 AM
Cool Humidifier?
You could easily locate one new on eBay or go to your local department store. There are several brands. A one gallon humidifier should work fine for you. $50. or less as far as cost. Also, a good humidity gauge would be good so you could monitor the humidity level: Radio Shack carries these and they are not that expensive. A 47% humidity range is good level to maintain.
Old 05-04-2009, 12:34 PM
i would like to buy it new. i have a hygrometer and i try to keep my room now from 35% to 45%. any more than that then my bass doesn't ring like it should. do you or anyone else have any positive first hand experience with a specific model or brand? i'll be moving to cleveland... i'm sure it's not too different than chicago, but if anyone else has a different opinion, please, share.
Old 05-04-2009, 03:21 PM
Default Brand?
I use a Honeywell and it works great. That or any like brand will work fine.
