Is there an amp head that has the ability to turn the volume up in order to bring the level inside the unit up so the bass sound will improve yet have a volume level adjust that will enable you to still adjust it so it is not playing at max or the extreme level the amp is actually set at? I know this is strange question but there is a reason.
Don |
Tim Bishop |
Or, if you are trying to control spikes in volume while you are playing, compression is an option and there are heads out there that include compression in the chain. Some better than others.
Tim Bishop |
Lesser amounts of distortion are achieved by balancing input and master volumes. |
Tim Bishop |
The reason is the church I play in is stating I am too loud. Well the Fender Rumble 100, although not the best amp, sounds best at 3/4 volume with my bass at least past 1/2 volume. They had me so low the other day I mine as well be playing my old washburn with dead strings. I was trying to get the sound, attack, brightness, tone, without having to have the volume at that level. I turned the amp down and bass WAY up. It still sounds good but the volume issues are still there. I realize there are optimum levels that speakers really should be to sound the best. I don't think they do.
Tell us about your overall church worship team set-up: 1. What are the instruments, vocals, sound system, being used? 2. If the church has a good sound system, are you fortunate enough to have someone qualified running that sound system? 3. How big is the room? 4. Are you using monitors and if so, what kind/type? 5. If you have a drummer, is the drummer playing an acoustic or electronic set? 6. If you have a drummer and he is playing an acoustic set, is he behind a shield? 7. What size bass speaker are you using in your bass amp? 8. Does your bass amp have an XLR Output? 9. Etc.
Tim Bishop Last edited by Tim Bishop; 08-25-2009 at 11:23 AM. |
The instruments are drums (acoustic), guitar (acoustic or electric), and/or piano. I am using a 15 inch speaker with a tweater (nonadjustable). THe drummer is behind a shield but they may a) enclose him completely, which I don't like, or b) mike the drums so he can hit them less hard. He just put acrylic heads on them so they are louder. (BTW he player with George Straight and Waylon Jeninngs). He wants to be enclosed. My amp does an XLR output and I use it to go to the house. The board and system is all wrong and a sound guy is coming in. The church has 27 foot high ceilings, wood floors, a rock wall where the instruments and improperly installed sound deadening material on the side walls. It is a great echo chamber when no one is there. They are fixing the material on the sides. They are using peavey monitors (std looking and size). I am not in the monitors since I am plenty loud. The three of us sound really good togther and click. We just have to get the sound straight. Hope this helps. I was going to get an Eden WT 550 head and a decent cab but think that is serious overkill for that church. We have four house speakers on the ceiling that are chained. The sound engineer will be unchaining them for independent volume controls. That is also a volume issue. That is one reason I can not be in the house, I over power everything. Amp recommendations would be nice. I have a tendency to by good stuff and keep it, ie: my Pedulla. I do like versatility.
Don |
Tim Bishop |
The 15 may be too much for your current set-up challenges. 12's and/or 10's could help you hear yourself better on stage. Have you tried getting your bass mix through your monitors? Once the drummer is completely enclosed, you should give this a try; at least in the interim, until your overall sound upgrades occur.
Tim Bishop |
Wonderful...I got the 15 because I have tried 12's before and the B string just won't cut it. I haven't tried good 12s or 10s. That is one reason I was thinking of getting an amp head with a separate cab. I thought I may have better control with the head and say a 210 cab. ??
Tim Bishop |
The WT-550 is a great head and I would highly recommend getting it or the WT-405. As far as cabs: Look at Eden's 210XLT, 210XST, 212XLT, and 410XLT's. These cabinets are VERY efficient with SPL ratings in the 106db range. Stick with 8 ohm cabs as you will have more coverage options down the road with the WT-550's ability to run at 2 ohms. Don't worry about "too loud" with this set-up. You can NEVER have enough headroom in your bass rig set-up. Think of it as having all the control you will need for most any room. It's not always about volume given the right set-up.
Tim Bishop |
Tim Bishop |
Tim Bishop |
Funny you should say that, I could not hear myself very well at all last Sunday. I looked at the WT-405, on-line, and read the entire "amp" thread. I haven't heard of anyone using the WT-405, at that I can find. Is it a good head and will it give good tone with plenty of options? I don't see much difference over the 550. Maybe some tweaking ability. What do they normally go for? |
So with the WT-405 or 550 and the XLT or XST I could play at lower volumes and get the sound, or better sound, than I am currently getting?
I have both the 550 and 405. Both heads are great. If I chose between the two, I'd go with the 405. Why? There are more options on the 405 (including a studio quality compressor) and two inputs. Both the 550 and 405 will run at 2 ohms and are close in output level. Here's a link. Go check them out. http://www.eden-electronics.com/prod...mps/index.aspx
Tim Bishop |
![]() Quote:
Tim Bishop |
| Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
