Old 02-27-2010, 12:03 AM
Default Bridge Price
Does anyone know what the ballpark figure is to get a pro quality bridge made with aluminum adjusters? The only "quality" shop near me is charging $550.00 for a bridge with aluminum adjusters and that's before taxes...Seems high?
Old 02-27-2010, 08:57 AM
Depending on the market you're in, I don't think thats too far off the mark. Though, I haven't had to replace a bridge in a long time.
Old 02-27-2010, 01:04 PM
Lightbulb ??
Why do you need or think you need a new Bridge? Unless it's broken, warped or 3/8" or more too low the old Bridge should still be usable. I have shimmed many bridges in the legs of the un-threadded part of the adjusters from 3/16" -1/4" height or so after re-cutting the top to re-space the notches to my liking. Just because you don't know how to do this yourself doesn't mean you need a new bridge. That is assuming we are at option #4 and not 1-3.
Old 02-27-2010, 01:24 PM
Adrian Juras's Avatar
Calvin, if you tell them that you want a student model they won't charge you near that much for it. It is basically how long they spend on detail work. The foot fitting, and arch are just as good IMO.
Old 02-27-2010, 01:32 PM
Calvin, if you tell them(I assume Heinls) that you want a student model they won't charge you near that much for it. It is basically how long they spend on detail work. The foot fitting, and arch are just as good IMO.
Please no assuming. This could be a store, person in Toronto, Boston, anywhere. I don't want any person or store named.
Old 02-28-2010, 10:30 PM
Lightbulb too high?
IMO - it is high, unless there is a lot of work to do on the finger board, nut, or tailpiece/wire to allow the bridge to function correctly. Just the bridge with adjusters- it's too high. IME, the best bridge available with adjusters fitted shouldn't run over $450 regardless of the location in the U.S.
I think Location has a lot to do with price. It is tied to overhead and how much an hour costs in that shop. I heard that one major NYC shop is charging close to $700 for a bridge with adjusters. That to me is high. I think $550 is high too. Working in your Garage and working in a commercial space in a big city means prices will vary. Now, if the guy in the Garage makes the same product as in the City shop then it should cost less on the overhead side but not necessarily. Getting what you pay for is not always the case either. Some shops charge $50/hr and some $100/hr. The quality or grade of work is not always better in the more expensive shop. Also, the more expensive shop is not necessarily making more net profit either. They have a bigger rent and overhead to cover.
Old 03-02-2010, 11:43 AM
Charles A Thomas Charles A Thomas is offline
Charles A Thomas is on a distinguished road
Talking bridge adjusters
Check to see if the bridge fits the top, if it does and it is not leaning forword, if so the bidge is fine, string spacing can be changed fairly easily, and putting adjusters on is not rocket surgery.
