#81
I completely agree there aren't many Master builders out there, my questions here are meant only about Smith basses. Where I'm from, both originally and where residin now, there are NO techs to properly set up basses, or have too much knowledge concerning them at all. I do dearly love the feel of a nice, oil finished instrument. I have yet to be able to afford a Smith built for my needs exactly, but the one I have I got very reasonable, it's in good shape, sounds amazing and I wouldn't consider it a "dud" in any way. Compared to my 18V Jazz bass, its output is less, but it's more of a feel thing than an actual jump in volume, per se. My Smith has the hard finish on it, and though pretty, it doesn't have the crazy grain or figure in the wood I've seen in some Smiths. I was wondering if the finish did change the tone or appearance of wood, as compared to an oil finished bass, and I think got the answer. It's all subjective. Heh. I would never have ordered the hard finish on a bass like a Smith, but I must say it's aged well. It gives the bass an antique type vibe, and though would've never said in a million years I think I like the finish in the end. I've gotten used to it and really love it. So, I ain't changin a thing. If I want a new preamp, I'll get a new Smith. Someday...
#82
one thing I would like to see new is a lighter weight hardwear. I have own 2 Ken Smith BSR5GN and they were both a little bit too heavy, when I was cleaning both of them, I removed the hardwear for cleaning I realiase that the bass it self is light, and I could feel how heavy the hardwear was. I would be great to get a K.S. bass that weights at least 9 LBS.
Psalms 33:2-3 |
#83
Another consideration: Some woods are heavier than others too. Personally, I don't have a problem with the weight of any Smith I've ever owned.
Tim Bishop |
#84
Hi All,
In fact I like the fretted Smith basses as they are and I am pretty sure there will not be so many changes in the future, as this design showed at what level the basses are excelent made and thought. Nevertheless, my thoughts are in the fretless area. I wish it would exist a specific fretless design/model with the following features/options: - only one sweetspoted pickup - option for a piezzo pickup considering the exceptional sound the Smith basses deliver. - longer fingerboard (joining the sweetspoted pickup or at least 28 fretlines) so no need for a neck ramp. - chambered body in order to achive more acoustic headroom.(especially usefull with the piezzo pickup) Am I dreaming too much? Best regards |
#85
I don't know if this has already been mentioned before but I would like to see an option for a shorter headstock on 7 string Smith basses. I played a six string Smith for many years and now with the 7 string I have to be much more careful not to knock people in the head when playing music in tight quarters. I'm getting more used to it but it would still be nice to have a headstock which is closer to the same length as a six string if it is possible.
I've imagined that perhaps 3 tuners on the top in normal spacing with 4 on the bottom using a very tight spacing, probably almost touching tight, could possibly work and come out to about the same distance as the 3 top normally spaced tuners. Perhaps the F string tuner would need to be slightly closer to the nut than the B sting to achieve the equal distance at the A and D string tuners. I'm not sure about the details but if this could be done it could lesson the length by around 2.5 inches which may not seem like a lot but again when playing in tight corners going from about 8.5 inches to 6 inches of headstock length would be nice. I've even imagined a couple of ways of modifying my own bass to achieve this but then I regained my sanity and thought better than to even think about going down that road. |
#86
I wasn't really thinking a smaller head, just the length of it so I think the distance to the edge might be able to stay the same but strength certainly would trump a couple and a half inches of length in the headstock so if drilling the tuning machine holes closer to each other would make it weaker then it certainly would not be worth it. And, like you said, basses get bumped all the time so again strength wins out. I've dealt with basses in the past that had very close tuning machines and it didn't bother me but I can see how a lot of people would probably not like that. Thanks again for your reply and your time! By the way, thank you for making such fantastic instruments! I hope you have time to get out and play some golf. Brian |
#88
I almost had the problem with the headstock - but the problem was really the other musician standing too close to me.
Last night, the guitarist kept standing too close - so I put the headstock about one-inch from his nose. He stepped back. No problems with my Smith7-string bass. None.
#90
I would change the string spacing to 16mm like on the Burner Basses. For light touch, fingerstyle playing it is so comfortable. There is absolutely no way a US made Smith Bass could be ordered with 16mm string spacing??
#92
Sleek Elite in Japan is making a re-issue Burner model now in 16mm and it's very high quality. |
#93
Ken Smith MD7 - I would only change the number I own.
![]() A White-Tiger MD7! I am accepting donations for worthy cause. Contact me for the donation website - really, contact me ![]()
-- Christopher Rhodes www.crjazz.com chris-rhodes@comcast.net http://www.youtube.com/watch?v=LtLy4wtJy4k Last edited by Christopher Rhodes; 11-08-2010 at 12:53 PM. Reason: edit for spelling, and more spelling errors |
