#241
If were going through foh I only use the one cab as an onstage monitor, I only really use the 2 cabs for the outdoor big gigs we do,
I'm going to try the nav out on Friday & I'll let you know how I get on with it, Do you think the nav will sound close to the wt550 or 800 ? |
#242
Remember - the WT550 and 800 are also power-amps. All three share the same Parametric EQ feature, Tone Controls and a few other options. However, with the added features the Nav provides coupled with a quality power-amp and right cabinet or cabinet combination (lets call this set-up The Beast), I give the advantage to The Beast and I've used both the WT-550 and 800 heads. Both are great heads (no question).
Tim Bishop |
#243
Thanks for that Tim, I'll let you know how I get on Friday,
Al |
#244
Tim Bishop |
#245
Oh well, it turned up but wouldn't switch on, I checked all the obvious fuse, mains cable ect, gutted,
#246
Can you elaborate?
Tim Bishop |
#247
It just wouldn't switch on Tim, there was no flicker or anything, I checked with a meter & there is power getting to the jumper leads inside, maybe the transformer has gone? I'm no tech so it's just a guess really,
#248
Not following what you are referencing. What wouldn't switch on?
Tim Bishop |
#249
The on off switch on the navigator on the front panel, the switch moves ok & is working, I tested it with the multimeter but the nav won't power up,
#250
Are you sure you have the jumpers (inside the navigator) in the correct place to accept the voltage of your country. Is the voltage in UK 240v?
Tim Bishop |
#251
Yes I checked that & they are set to 240v, I'm gutted, I was looking forward hearing my smith it,
#252
. That's too bad because the Navigator is an amazing pre-amp.
Tim Bishop |
#253
I might try & find another one, Al turner uses one so it must be good
#254
Sounds like a plan. You won't regret it.
Tim Bishop |
#255
I play my CR5 through a acoustic image focus 1 and accugroove tri112L+tri115L...I hear the sound of my bass, flat response, unclored...heaven
#256
I prefer the Euphonic Audio Doubler with the Wizzy 12 M-Line. For coffee shops, I bring the Doubler with a Wizzy 10 just in case it's needed (but this is with DB).
Even though the EA Doubler is designed to be for folks who play EB and DB, the EA Doubler with Wizzy does very well with my 5-string EB on Funk and Latin Jazz. |
#257
I normally play a Eden WT800C with a Bergantino 410. My secondary setup is a Eden WP100 hooked up to a Carvin 1000 watt power amp, played through an Epifani UL410
Des |
#258
Des |
#259
Since I first posted on here my rig has changed a little. I'm still using the black tiger elite as main bass, but my main amp is the SWR SM900 and I'm using some Bag End cabs- two D10BX-D cabs and a powered S18E-D with the low frequency integrator. An amazing set up for me, and I can split the rig for different sized shows. I get a clear, uncoloured sound with a stage shaking rumble when I use the full rig!
#260
Des |
| Currently Active Users Viewing This Thread: 20 (0 members and 20 guests) | |
