How much lower will the action be setup for medium light strings?
Des |
Lower? From mediums? The G and D are the same. The A and E (and B for 5s) are lighter so, you will need higher action, not lower action to maintain the same tension or feel.
I want to lower the action so I can play lighter. Its hard to tap and double thumb due to the high action. Another reason why I want to start using medium light strings.
Des |
You can lower the action and maintain tension easier with the TCRM than with ML.
How does this work? Why would be easier on Medium than Medium light? Does this same concept applies to Burners TC ? Thank you! |
ML had M tops and L bottoms. Not as balanced as Ms or Ls across the set. |
Let me know, thank you for your time Ken, |
You wont know till you try it.
And on your experience, what has worked better for this purposes ?
I don't use a set-up like that but also never used lights for any period of time.
Thank you Ken, |
