Go Back   Ken's Corner (Bass Forums Sponsored By KSB) > Electric Basses > Music [BG] > Member Bass Clips [BG]
Old 01-10-2008, 04:11 PM
Christopher Rhodes's Avatar
Default MP3 Sound Clips
Here is a little solo I recently performed. Disregard the bad notes - just check out the range of a 7 string bass. Amazing.
Last edited by Christopher Rhodes; 01-10-2008 at 04:16 PM. Reason: insert mp3 file
Old 01-10-2008, 07:36 PM
Default 7-String
Sounds good Chris. Am I hearing the LM II in action?
Old 01-10-2008, 08:02 PM
Ronson Hall's Avatar
That's a very nice solo, Chris! You ought to feel fortunate to be blessed with the chops you have! Very nice...
And, to Tim's point, please list the eqipment you were using as you created that solo...
Ronson C. Hall
www.TrueLightSA.com
Old 01-10-2008, 11:28 PM
Default Yes I was using the Mark Bass LMKII amp ...
Yes I was using the Mark Bass LMKII amp with a bag end 4x10 8Ohmn speaker and a Nahas 1x15 8Ohmn.
I was going to use some effects (Boss ME-50B) but I decided against it - although I did accidently step on the volume during my solo and cut off the sound totally !
One day I will get a chance to check out a WT550 Eden head, but until then -the LMKII will due just fine.
I have another clip to put up a little later - tomorrow maybe.
Old 01-11-2008, 12:51 AM
Cool Recorded with?
Chris, what did you use to record that tune in order to produce what your .mp3 upload represents?
Old 01-11-2008, 01:41 AM
Default I use the Zoom H4 recorder...
I used the Zoom H4 recorder in MP3 mode; 128 stereo.
The recording was a little low, so I use calkwalk pyro to bring the volume up and to chop the tune into the section that is uploaded.
Besides the Markbass LMKII, the Zoom H4 has was one of the bette purchase for 2007 no doubt.
I generally use the the H4 on a tripod in front of the band - in that sweet spot about 10 feet in front of the band - sometimes just a little closer to the me on bass.
Lots of MP3s online at www.crjazz.com/radio
I just added another .mp3 file also
Last edited by Christopher Rhodes; 01-11-2008 at 10:40 AM. Reason: edit... adding another .mp3 file solo...
Old 01-17-2008, 08:52 AM
Default Ken Smith Desiged 705 + LMKII
As most of you know the KSDs are designed and setup by Ken Smith - and too great effect. These are tone monsters IMO.
The attached clipped from Dec 16, 2007 - Ownings Mill Md.
KSD705 + LMKII + Bag End 4x10 + 15 Nahas = (listen to attached clip)
The KSDs have are totally different smith (designed) basses.
Old 01-17-2008, 08:57 AM
Lightbulb set-up?
Set-up? NO.. Designed by? Yes
It is a Brooklyn Gear product. We never see them unless BG brings them over for testing or trouble shooting? When designing a new model is the other time we are involved but they have some other people for setting them up in NY.
Old 01-17-2008, 02:42 PM
Default KSD Setups
http://www.kensmithbasses.com/KSD/ksd_test.htm
The above link lead me to believe all the KSDs where test by you - but now I see you only check "A selected few".
Old 01-17-2008, 06:29 PM
Lightbulb Please re-read...
"Ken and crew test and adjust "a portion" of every production run of the KSD's to ensure the 'Smith' feel and sound is included in the 'mix'."
This was mainly in the beginning when the Basses first came out. After the first year, it was no longer necessary for BG to bring Basses here unless they had a problem to troubleshoot.
Old 01-17-2008, 06:35 PM
Thumbs up Changed..
I just updated the Web page where that statement was posted.
"Ken and crew 'tested' and 'adjusted' a portion of the first 'few production runs' of the KSD's to ensure the 'Smith' feel and sound 'was 'included in the 'mix'."
Ok, I hope this clears up any confusion on the matter. Thank's for bringing it to my attention.
