OK, since you asked I will submit my two cents here!
I agree with the observations people have made so far but I am surprised because I thought the use of these bridges was quite well-known. These "wing-less" bridges were introduced to me over thirty years ago by Ludi Pollak, the wonderful repairman and bassist in Toronto. He and his father were well known luthiers in Bucharest before coming to Canada and one of their clients was Vladamir Orloff, the great cello soloist. Orloff was practicing one day and mishandled his bow; he accidently knocked the wing off his bridge on the C string side, and was amazed at the increased volume and focus in the sound. With the Pollaks help, he developed this into a belgium-stlye bridge with no wings. When Ludi and I started playing together in Hamilton back in the seventies he made me one and I have used one ever since and have learned alot about them. They will absolutely make your bass more audible and easier to hear in the orchestra and they make it much easier to bow for some reason. The wings are tone filters for the high end frequencies and are really just little mutes on the bridge; ultimately you can control better how "dark" your bass is. If you want clarity but not so much treble in the sound, than don't cut the wings but just try and get the overall weight down. I can't remember the exact numbers now, but at some point I was fairly into all of this. I think that a normal bridge might have been around 140 grams? (my numbers are probably all wrong), I think I thought the magic number for me was 120, but I am not sure. My friend Wolfgang Guettler was also into this; he had a bridge that was so thin; maybe 100 grams! he took a bridge, cut it in half and had a thin veneer of ebony inserted! This prevented it from warping, which I should mention is the biggest problem with a low mass bridge. I don't recommend these bridges for all basses! If you have a dark bass that is hard to hear when you play in orchestra, then you have a candidate for the "procedure"! (You used to have to go to Scandinavia for that!) Having a wing-less bridge on a bass that is already clear and open (bright) can be a real pain to listen to. It all has to be done with taste; with my style of playing you have to hear yourself play all the time so having a bridge like this is helpful but you don't want to inflict yourself too much on your section mates. I would be cautious about showing up to an audition with a wing-less bridge if it isn't held behind a screen. I think that many of the notions of a dark set-up and "blending" are not compatible with the clear and open sound of a low mass bridge. Just seeing that you have no wings on your bridge might indicate to some people that you are not going to "blend". Personally, I think that the best blend comes from everybody having great intonation and rhythm and that is only possible if you can hear what notes you are playing, sort of like the way all the other instruments work. I would also like to mention that the best sounding bridge I have heard lately was made by my student, Ian Roberts, and it looks normal (with wings!) but it is very light. The quality and density of the wood make a big difference as well. If you use adjusters in your bridge then cutting the wings off can counter the effects sometimes; I am not a fan of metal adjusters, but for me, they become bearable with no wings. I have sometimes wondered how and who decided on the modern shape of the double bass bridge that we have inherited today; I have seen on some old basses in museums etc..bridges that share many qualities with wing-less bridges, for instance low-mass, high arching, no feet, not to mention no wings! |
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
