Old 06-23-2009, 10:43 PM
I am not sure of your exact question but I will tell you how I file a nut. The strings enter straight in from the fingerboard and are angled back to the tuners or the other way around but one end of the Nut goes to a straight pull and the other an angle. The slot must follow the angle. I use a jewelers rat-tail file. Nicholson's are the easiest for me to fine here but "Swissmade' are as good but impossible to deal with that company.
The string should not be under the surface of the Nut but like the bridge, 1/2 -3/4 the depth of the string diameter. Same diameter rules to be used as on the Bridge, just the other anchor end and different wood. As you file deep, stop and rasp off or file off (depending and using a flat file of sorts) the excess ebony so the slot is not so deep. When all done, sand and polish it carefully and oil up the Nut.
Be careful not to slip with the file and hit the bass with it. Also, wear glasses or safety goggles. If you pull out of the slot quickly while filing fast and jam the file tip into the edge of the Nut missing the slot, the tip of the file can break off and go in your eye. I have had tips hit my face and forehead. I count my blessings.
Now, please do not get my next statement confused with something else.. ok?
I have handled more Nuts in my life than most Double Bass Lutheirs..
You know.. the Nut for the strings.. lol.
In my Electric Bass Business, I have handled over 5,800 in Brass alone. Brass Nuts.. Try them on for size..
The Ebony DB Nuts are easy for me in comparison to cutting Brass. I made a wide stepped Nut of Ebony for my Carl Thompson Electric Bass back in 1973/4 way before I started my business. Carl asked me NOT so Show off my NUT because everyone else will want one. Just one Ebony NUT, what harm can that do?..
So, filing the Nut slots from the FB to the peg box it's at an angle. The Nut shape will follow that pattern or it will be too high over the strings.
I made this temporary Nut the day I bought the Bass. Simple but functional. Note the gentle slope/angle from front to back, fb to peg. It stayed on the Bass till Arnold chopped the Neck off and be-headded the Scroll/Pegbox for its restoration. When it's done, it will have a new Grafted Neck, a C-extension and a new Nut for 3 of the Strings next to the Extension as usual.
Thank you VERY much.
