.Oh well, at any rate..... This first thing that comes to my mind is your bass is not set-up optimally for your playing style and/or technique. Did you get the link I sent you (from this forum) of how my set-ups are done, including all the measurments of string height, etc.??? Let me know. If not, I'll send you the link again. This would be a great starting point for you, and from that you could tweek according to your playing style. BTW - I'm curious, are you using the Smith Medium Taper Cores I recommended to you??? Depending on how you're attacking the strings, and how your bass is set-up with the strings you are currently using, could very well be the cause of what you are hearing as "click issues". Also, on your 210XST(4), check the back panel. You have an adjustment for the tweeter. If you have it set too high, you may be hearing excessive higher frequencies cutting through. That cabinet is VERY efficient, so, double check that setting. Do not turn it off (or turn it fully counter-clockwise), BUT, start it at about 9'Oclock. Most anyone that has a clue about that particular cabinet finds the 9'Oclock tweeter setting is just about perfect. However, use YOUR ear to determine that. I would not send your bass anwhere for a "repair". It's unlikely it's the bass and most probable it's the overall bass set-up. Sending it in to someone that doesn't know how the bass should be set-up for your playing style is a hit-or-miss proposition and most likely, you'll be throwing your money away. Make sense?
Tim Bishop Last edited by Tim Bishop; 09-07-2009 at 10:44 AM. |
