Old 01-29-2010, 07:37 PM
Cool smiles...
Didn't David Wiebe copy that bass?
Good for you Ken, that will turn out nice I think.
I would measure the plate resonances of the original when it is in restoration.
I would measure the density of the plates.
I would copy the exact bass.
I would laminated the ribs just as they were originally except I might use different thickness veneers. I can explain this if you wish.
Corners will change the way the corpus vibrates.
Ken, I can have it copied 100% if I like, 44 1/2" string length and all. The facts are that I DO own the original and I want to have the copy different. I already know what the original sounds like. I also know I will not live 200+ years to hear the copy age like the original has. Also, the bass has been repaired over the centuries as well and I will not live through that either.
I have used the original in Symphony concerts so I know very well what I would like if I owned a twin with the desired modifications. This is it, the twin, modified!
You would need wood from the same boards as this to make it exact but even then, it wont be. Only the exact is the exact.
I know David's copy BUT, to my eye it is more of an inspired copy than a copy copy. It was made with Walnut, different Scroll, different FFs and, he didn't have the original apart in his hands at his disposal to copy from. Arnold has heard the Wiebe copy and it doesn't sound like the original. Perhaps nothing will. The original has been re-graduated within the last 100 years or so and we have to 'guesstimate' what the original thicknesses were. Actually, the bass is currently 'reverse-graduated' The bass is thinner now in the middle and thicker (original) around the outer edges as the center was cut up quite a bit. We will use something more traditional and maybe tap tone the Top along the way making it to the actual wood chosen. We will have to ask Arnold when all is done how he arrived at the final thicknesses. I say we but 'I' am not the maker here. Arnold Schnitzer is. The 'we' is us, maker and player/designer but without 'me' commissioning this, it would never happen.
On the Ribs, they will be solid, not laminated. We can see now how cross grain Spruce against Maple reacts after 200+ years. Not something I want to see in my lifetime. I will however have the Rib depth and top to bottom tapers copied. This will not be a very deep bass at all. It tapers 7 3/4" to 5 3/4" Block to Block.
I asked Arnold to copy as close as possible and make the same Purfling as well. I also want that Scroll/Pegbox copied. It might get slightly extended in length if it helps fitting the C-Extension as this was a 3-string. How would this maker have made the Pegbox if it was to be a 4-string originally? This is in thought for now. We can use the Original to measure from and decide from there.
Maybe we need to have a mini-convention of all the recent Cornerless Bass copies and inspired models which this one actually is. I am not all that concerned how much the corners will affect the sound. The inside lines of the Bass will flow in the manner of mainly a Guitar form.
