Old 05-07-2010, 11:08 AM
Cool well..
Yes well my instinct was to change that single brace to a more "italian" style of cross bracing. I was also wondering whether by doing so the "integrity" of the "french" bass would be compromised. But this is not a museum piece, has no makers label, and is being restored to play.
That's interesting what you say about the bandsawn linings - I was wondering how on earth you could BEND a 12mm strip around that sort of radius! I'm inclined to leave the other linings as they are, though ... I can't see much to be gained by lightening them.
Arnold the stop length is 570mm. What does that tell you?
The Stop length plus the neck length plus an inch tells the approximate string length which would come to about 41.5". The Neck from heel to nut would be about 18" for a D-neck heel.
The Linings should all be replaced. The larger linings inside stiffen the ribs and hinder vibration.
Label or no Label put a normal center Brace and a lower and upper brace as well. I think 3 braces are fine regardless of pedigree. My Mougenot has the same single brace and it's coming out and most likely just what I told you for braces. If you like, my bass will be done before this one and I can tell you what was done, if you like.
Ok? ok..
