Old 02-14-2011, 02:40 PM
I think the faster the better. Hot hide glue is strong as it work at a molecular level. If it create a bond it will fail, as the glue itself is brittle. So it's better not to let it jell, but to clamp fast and with a good pressure.
This way the extra not needed amount of glue will go out from the joint.
If the glue jell too soon, maybe it is too thick, or the workshop is too cold.
A good joint, as far as glue thickness and temperature go, is when the surfaces don't slip, after rubbing, even before they are clamped.
Good luck, Ruben, you have a nice project there...
oops, sorry Arnold, I was typing while you was answering...
That's 100% answer my question thanks... I though so but I wasn't sure… I guess sometimes you can’t believe all that you read… I will keep it simple
