Old 05-09-2011, 04:30 PM
Chuck Laranjeira Chuck Laranjeira is offline
Chuck Laranjeira is on a distinguished road
Default Burner Questions
Hi,
Recently became a pround KS owner!
I just purchased a used Burner serial number 981571 DA4.
I think the electronics may need some work as I 'm having difficulting sorting out the control knobs other than the volume. I know that sounds like I'm a complete moron but seriously what position is the blend / bass / treble. I'm not hearing a significant difference between settings when playing with these 3 knobs. The bass came with no documentation. Would appreciate any info you can provide on this model. Also if the truss rod adjustment is under the "burner" marking on the headstock or if the neck has to be removed to adjust. Also I noticed you are in PA - I'm in NJ would you be willing to adjust / setup if I brought it to you? and how much would that cost?
Thanks
Chuck
