View Poll Results: What Length 'B' String would be best for your Bass?
36.5" From Ball to Silk or Taper 5 45.45%
37" From Ball to Silk or Taper 2 18.18%
38" From Ball to Silk or Taper 3 27.27%
39" From Ball to Silk or Taper 1 9.09%
40" From Ball to Silk or Taper 0 0%
Other length? Please explain in your Post ! 1 9.09%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
Old 02-17-2008, 07:38 PM
Lightbulb length..
Ken,
I measured my bass and it is exactly 35-7/8" from the ball to the tuning peg side of the nut. It is another 2" to the center of the tunning peg at the B string.
The 38" winding length on the Rock Master Medium non-taper core low B is too long for this bass.
I end up with the thick part of the string at the post.
This only occurs on the low B string.
Can you suggested a B string that will work?
Are the taper core strings a little shorter?
Thank you
I have some gauges in the non-taper in 36.5 inches. Unless they break tuned to pitch, the 38" should be ok if you can cut some of the silked portion of the 'spread' which needs to be done anyway. Just make sure when you call and order you ask for the shorter B, if we have them. Unless you over tune them, they should be ok and not break.
