Old 12-27-2008, 10:14 AM
Cool the Js?
Originally Posted by Roger Vaughan View Post
Well the value for me will be more related to the sound I can get out of it, but again, I may be looking at it too hard. Strings is a good point, I had a set of rounds on a beater bass and it sounded kind of sour and awful. I moved the set onto another bass I like quite a bit, and then that bass sounded awful too! So that was pretty defining for the scope of influence strings bring into the mix.
I played the Burner for a set last night at a low-rent bar gig, but without the active eq. I'd thought the bass was unplayable in passive mode, but was incorrect. Sweet player, but very honk-ish sounding. This may have been due to the fact I was playing through a small, cheep mixer for a pre into my Crest power amp! Nonetheless, I'm thinking it let me know the passive tone of the bass without the benefit of ''proper'' bass eq. Gonna have to do something for this, here, and I'm guessing I'll go ahead with the original plan of the replacement pre circuit. There is a reason I like Lesh's old sound so much- like the bass line on "Casey Jones"- and though he used a different Smith (with the pickguard and a hundred knobs and switches!) and different guts too, this is as close as I'm getting for now.
So just out of curiosity, what's the difference between these p'ups in here now- the J's with the Smith logo- and the ones in the previous models? Anything remarkable?
Never compared them all that much. It's just the Pickup design I chose for the Bass when I was in Japan finalizing all the details. The Burner is the Burner. I don't know the condition of your circuit or battery now and without seeing it, can't tell you if it's even working right or our circuit to begin with. When you buy an old Bass used, more often than not it needs a trip to the shop to be put back on track and sound like it's supposed to.
Old 12-27-2008, 11:05 AM
Roger Vaughan's Avatar
Roger Vaughan Roger Vaughan is offline
Roger Vaughan is on a distinguished road
I'm there with the trip back to the shop, you're definitely going to see it as soon as I can pull up the scratch.
There seems to be, for me, a lot of mystery concerning the sound that comes from a circuit and what components or combination thereof make that sound. Eq is eq... is eq,... in that a freq or bandwidth is really an objective idea. But we come up with a circuit to give us a 'pre-shape' eq curve, and that circuit also often adds a 'color' of it's own. Examples: Joe Meek, Trace-Elliot, Ampeg... Honestly, the stupefying number of preamps (both inboard and outboard), amplifiers, rack-mount systems, processors and pedals available is enough to put a knot in my head. And of course now we're talking about pickups...
For years I've steered clear of active stuff just to avoid the clutter of too many items in the gain-chain! But I now have 2 active basses. So the moral is that if it sounds good, it is good- and that's where the thinking stops. Thank God.
Glad to have the bass, we'll get 'er fixed up. Thanks for the banter Ken, folks!
Edit: Oh, and about my previous post above concerning the sound of the Burner "passive", I don't know what strings are on it. Maybe it's the strings...
"Whatever we do, it is what it is, and we do it."
-The Grubs.
Last edited by Roger Vaughan; 12-27-2008 at 11:10 AM. Reason: Clarity, better read, added a note.
Old 12-27-2008, 01:47 PM
Lightbulb Active/passive..
The Burner Bass and all other Smith Basses are actually made as Passive Basses, with Passive Pickups, Passive Volume and Pickup controls but with an Active EQ that is either Bass/Treble or Bs/Mid/Tr that is mainly colorless, like a graphic type EQ. The Bass can be set flat in the Active mode and have within 95-98% of the exact sound as the Passive Push/Pull (up position) By-Pass sound. There might be a tad 'bleed thru' from the active EQ circuit when in passive bit it is NOT designed at all to color the sound of the Bass, just to EQ it like you would in a studio, boosting or cutting a particular Frequency point with the range above and below the EQ point shaping the sound.
Old 12-27-2008, 09:30 PM
...There might be a tad 'bleed thru' from the active EQ circuit when in passive bit it is NOT designed at all to color the sound of the Bass, just to EQ it like you would in a studio, boosting or cutting a particular Frequency point with the range above and below the EQ point shaping the sound.
Do you happen to know the frequencies where the EQ affects the signal for lo and hi? It's shelving, I would assume. I'm just interested.
-The Grubs.
Old 12-27-2008, 10:17 PM
Cool Freq's..?
The Bass 'shelf' then I think was set at 100hz. The Treble is a peak filter and the center is about 3500-4000 hz (3.5-4k).
This means little unless you know how the 'shapes' work. The Treble lower part of the 'cone' is about 1-2k and is cut off at 20k. The Bass shelf cuts off at 20hz bottom and goes up the the mid area at the tail of the shelf.
Tech talk. Means little unless you can taste it from cross town from, just seeing the smoke!
Old 12-28-2008, 11:49 PM
Well I'm going to be very interested to hear/play this baby when she gets back from home. Thanks for all the informative replies.
-The Grubs.
