Old 01-29-2009, 01:22 PM
Aren Winebrenner's Avatar
Aren Winebrenner Aren Winebrenner is offline
Aren Winebrenner is on a distinguished road
the Bass Bar like any other part of the instrument needs just as much thought as anything else in a Bass. Maybe even more!
That's what scares me!!!
I have made just one instrument so far, under the tutelage of Kevin Flannery in Grand Rapids, MI. So I'm very new to all of this. I picked up a "very distressed" turn of the century Germanic shop bass as an instrument to practice various repair techniques on (as it needed just about every repair imaginable short of a scroll/neck graft). It had an integral bar with cracks to match, so it had to go. I used Kevin's methods for determining bar length and placement. Which brings me to this. I have discussed this with Kevin, but with everyone having their own idea of how to approach it, I thought best to see what some of the other battle hardened veterans have to say!
Thanks Ken.
Old 01-29-2009, 02:02 PM
Question humm
Thanks Ken.
Short of a Graft? Let me ask you a few questions so we can be sure the neck is correct. I ask this because it is easier to work on the Neck before you close up the Bass. Getting the old one out and the basic fit I mean. The Neck set is usually done with Top and Back on for alignment.
What is the Neckstand currently on the Bass?
Do you know how tall the bridge was with low string height before?
How wide are the C bouts?
The neck block (hope it has one) is mortise or dovetail joint?
These are some basics for consideration.
Old 01-29-2009, 02:30 PM
The neckstand is too short/low at this point and is in a mortise joint. I'll be carving a new neck block and adding to the heel to modernize the overstand. It's not the worst that I've seen but could definitley be higher. If memory serves me well, I think its only about 12-13mm as is. I don't recall the bridge height right now but I know it is on the short side. I don't recall the width of the C bouts right now either. I'll check it out when I get home tonight, and report back.
I hesitated to dive in on this bass, but given all the work that needed done to it, the repair/restoration costs would have far outweighed the value of the instrument. So I thought what the heck, I don't plan on this being the only one, and ya gotta start somewhere!
Old 01-29-2009, 02:45 PM
Lightbulb ok, but
My Gilkes neck overstand was about the same as yours is before it was restored and is now 36mm but in adding a Button to increase the neck stand, you have to watch the neck angle pitch and bridge height ratio. Get your 'numbers' lined up correctly. I would say 6.5" is about average height for a bridge with low string height.
The Block can be built up inside the bass if it needs to be deeper and in the mortise as well. Making a whole new neck block should be a last resort. Both my Olde English bass and my Hart had their blocks built up in both the mortise and the depth in the bass. The fit to the shoulders, back and top didn't need correcting. Just the added piece to the bottom of the block. Old wood is good wood unless it is unrepairable.
Old 01-29-2009, 03:22 PM
Agreed, I would rather not make a new neck block. However, at the base of the mortise, in the corner on the soundpost side, there is a crack that appears to extend, at a slight angle, down into the block about a 1/2" or so. I'd hate leave it and have it be a problem for the next guy that gets it worked on. He'd likely take it to someone for other repairs and then the luthier would curse my name for not taking care of business when I had it open. I get the feeling it only takes a couple hack jobs in this business to ruin a guy's reputation, and seeing how I have no reputation, I'd rather start out with positive reviews rather than negative!
Old 01-29-2009, 05:05 PM
Cool Block..
I meant that the Block can also be repaired as well. A small sliver of wood in the crack and then a piece under it for support possibly but then again, I am just guessing not actually able to look at the bass first hand.
Old 01-29-2009, 03:32 PM
My Gilkes was about the same before it was restored and is now 36mm but in adding a Button to increase the neck stand, you have to watch the neck angle pitch and bridge height ratio. Get your 'numbers' line up correctly. 6.5" is average height for a bridge with low string height.
I need to fix a shoddy button repair on mine as well. Could you post pictures of yours, before and after. Sounds like it may be a good point of reference for me.
And yes, I'm definitely planning on paying close attention to neck angle pitch, bridge height etc. I'll get the numbers right before I ever touch a tool!
Old 01-29-2009, 05:21 PM
Arrow Button..
Sorry, by button extension I meant an addition to the neck heel to push it out over the body for a bigger overstand.
Like here, before and after;
This Bass has a 'Back' Button Repair done about 140 years ago or so when the shoulders were cut.
For more inside pics of the Gilkes, scroll down on the link.
Old 01-30-2009, 12:38 PM
This is the plan for my bass. I haven't removed a neck from a mortise or dovetail joint yet, so this will be an execise in patience I'm thinking. I've read various things about this procedure, but having not actually witnessed it being done, I'm a bit nervous. Any tips are welcome!
Thanks for the pics by the way.
