Go Back   Ken's Corner (Bass Forums Sponsored By KSB) > Double Basses > Strings [DB] > DB Strings at Ken's Corner..
Old 01-23-2007, 01:50 PM
Cool Does this make sense?
Originally Posted by Michael Case View Post
I would assume if you're looking for info on a good string for arco you'd go to the arco string section. The same with pizz, regardless of what the string is marketed as. For instance I use an Oliv/Obligato mix, I play 99% pizz and 1% arco so my comments about Olivs would fall under pizz. Does this make sense?
Yes, 100%. Many strings have multiple purposes for various music styles. On the other hand, some strings work better on some Basses or with different players. Usually it's the Bass/String match. Bows help too in that area as some Bows just work better, period.
The sections are now up and running.
