Old 01-25-2010, 09:43 PM
Default ok, but...
Originally Posted by Charles Stark View Post
Thanks again to Ken for all the helpful information. It seems that this bass needs to have the fingerboard plained and re-profiled. It's a wonderful sounding instrument, it really anchors the section but the fingerboard is a bit off in design.
I've had to raise the adjusters up to 9mm on each side just so the G string gets 5mm of string height. It's a bit strange...The G and D string has virtually no camber, it's very flat... G (5mm), D (6mm)...But then the A is (10 mm) and E (11mm). So, there is a massive dip between the D and A strings. This means that the E and A strings are under a heck of a lot more tension than the D and G. That's why the bass feels so tight on the bottom two strings.
Basically, I need the G string side of the fingerboard to be lower (rounded), that way I could bring down the entire bridge.
How much fingerboard thickness will be left once this is done and set-up properly? This should be a concern as well.
