Old 01-30-2010, 12:18 PM
Cool humm..
Ok guys, A few current facts about the bass and the changes need to be spelled out.
On the original, the Top was thinned out to the danger point in the middle and lower bouts. The Top has 'sunk' in these areas as well.
On the original in repair it is obvious it will need some breast patching to bring 'up' the thickness in spots and then, level the graduations to the norm, what ever that is. So, tapping a tone now may give a false read as to what to make on the Copy bass because we are changing it from the start.
The Back is flat on the original with a center brace and 3 very shallow cross braces about the depth of a patch or cleat. The Copy bass will be round, not flat and will have a center brace as well.
The Top will have a similar arching system to the 'restored' original. The upper F-eyes and the F's all together are spaced too close. The original should have a 145mm bridge at the most but had a 170mm or bigger when I got it. The bridge foot on the 'G' side was crushing the Top inwards. The first night I had the Bass I cut about 5mm off the outer leg of each foot of the bridge and moved it up about 1/4" and this not only relieved some of the pressure, it made it sound deeper.
The Copy bass will have the F's moved up to match the desired string length within the same size body as the original and the F's moved outwards as well. It will get at least a 165mm bridge and the bar like on my Mystery bass was, might be in a bit from the upper F-eyes due to their wider width spacing.
So, we are copying the outline and Top archings (the way we think it was) and making the graduations the way we think is best. The Back is being changed from flat to round/carved but following the Top. The Ribs will be the same widths and taper as the original but in 6 solid pieces with small corners instead of two 2-ply continuous pieces without corners.
The Purfling and Scroll will be copied from as well but the pegbox might need to be longer for the 4-Gears to fit comfortably and the C-extension to fit without too much length protruding over the head. The original was a 3-stringer and the current gears are tight in there.
So, not an exact copy but a basis in which to center the design from.
Questions that arise in all of our minds might be;
1- how will the sound be at 41.5" from 44.5" if all else was left alone? Well, we are shortening the original so I will know somewhat the effect. Also, I had in the past stopped the string to 42" and re-tuned it to check the depth and if it was still there. It was and with even more focus so I know it's ok.
2- going round from flatback, how much change in sound or rather departure from the original sound characteristics will there be? Who knows? But, I am doing it. Flatbacks are just too much trouble to deal with. Round with a center brace is the way to go in my mind. The best combination.
3- how will the bass sound with the corner design change and with solid maple vs. 2-ply opposing grain ribs of maple and spruce? Well, in looking at the totally blistered 'blistered flatsawn maple' outer veneer, I hope structurally it will not be an issue or ever come to the condition the original has. As far as the sound goes, I have played many old bass with Organ like tone that were made like this, flat or round back so I am not worried.
The original Ribs will be repaired as best they can be but some restorers I am sure would opt for new Ribs entirely. The Copy should not have to go thru this split decision 200 years from now when it goes under the knife for a restoration IF it does!
Since the original is under a massive restoration at the same time the Copy is being made, it's not the same way other copies in the past have been made. Usually they get made from an 'in-tact' original with little or no modifications done to it and not taken apart either for corrective repairs.
Looking 2 and 5 years down the road, the restored original will be breaking back in from its massive surgery and the copy will be just spreading its wings. THEN, and only then will we know how well we did on both the restoration and the copy attempt. I know the sound of the bass from before and so do many others so I will not be alone in judging the repairs and modifications to the original. Making a Copy to the modified and repaired original before it's repaired is a big challenge in itself.
Maybe making the Copy now which will completed before the restoration of the original might help the actual restoration/modification as far as insight goes to what changes are in mind to clean up the original.
