Old 02-09-2010, 09:09 AM
First off, I would like to see the bass and make sure it's French as you claim.
Then, Arnold has had many of these thru his shop. If your bass is French, ask him what type of Varnish is usual on them, Spirit or Oil. French polish is usually not considered a finish but has been used including on furniture. He is currently working on my Jacquet and touching it up. He would be able to guide you much better than I can.
Ok Ken here are the pics ......
ID:	1453  Click image for larger version
ID:	1454  Click image for larger version
Old 02-09-2010, 09:34 AM
Adrian, decide whether you want to finish in spirit or oil varnish. Make certain there is not a single open crack or seam on the entire bass! Strip the rest of the bass, because you will never match it. Oil varnish is easier to apply, but is much slower; spirit is more difficult to apply, but is much faster. When applying oil varnish you should wear a respirator. As far as durability, oil varnish is more flexible and chips less. Spirit is easier to build quickly and to touch up. You can't go wrong with the products by Hammerl; over here they are sold by International Violin and Metropolitan Music. Any oil varnish you buy will require some thinning. Hammerl's tints work well, and mix right into the varnish, but plan on 10-20 coats to get to the color you want. Buy the best brushes you can find and take great care of them. As the saying goes, "It takes 10 years to make a good violin-maker, then he spends the rest of his life figuring out how to varnish the damn things". Good luck.
Old 02-09-2010, 03:10 PM
Hi Arnold , the advice is much appreciated . I have varnished a door frame and a breadboard before so this should be a breeze - seriously though , Ill get the varnish from the place you recommend and do as much groundwork as possible - I have a cheap violin to practice on first.
Old 02-09-2010, 05:15 PM
Exclamation finish..
In my book, if you can see the work, it has flaws. The more you see, the worse the job is. The more in looks like it 'grew' there, the better the job.
The first key to a good finish is the prep work. Finish or varnish will not cover up sanding scratches. It will amplify them. More mistakes are seen after the finish is on and cures than during or before the finishing process. Such is life..
Old 02-09-2010, 07:58 PM
Default varnishing
Arnold,
I couldn't agree with you more about your comments on making and varnishing. When I first started I thought that the making part was the hardest, now I think it's the varnishing.
It's too bad that bass was stripped. The original varnish was probably just fine.
If it was revarnished and turned orange, I'm thinking it might have been oil with a red brown color that is fading?
Old 02-10-2010, 04:20 AM
Originally Posted by Martin Sheridan View Post
Arnold,
If varnish it was revarnished and turned orange, I'm thinking it might have been oil with a red brown color that is fading?
the varnish was poorly applied as well as just simply being a crappy color !
Old 02-10-2010, 04:29 AM
I have noticed that many restorers seem to re finish their basses in darker brown colors ! Can this be to try and hide imperfections ?
Also does antiquing an instrument help hide imperfections ?
What does one do if an old instrument in need of a refin has so many dings on it that it is not possible or even desirable for that matter to fix them ?
Old 02-10-2010, 10:35 AM
Cool Antiquing..
Do not sand out dings. Only strip off the old finish and then apply the ground when startling to apply the finish. Chemically stripping the old finish is 100% better than sanding it off. Then you only have some light scraper marks to remove (hopefully) from lifting off the 'gunk' with something like a small paint scraper.
Do not 'try' to make the bass look new. Knocking down the gloss will help this. Also, some light antiquing tastefully done in the varnish will look better. Here is a bass of mine that was made from 2007-2008, just 2 years ago or so. http://www.kensmithbasses.com/doublebasses/lott/
You don't have to beat it with chains to help it look old. There is nothing worse than an old bass that looks new..
Old 02-10-2010, 01:53 PM
More good advice thanks !
The old finish was removed by chemical stripper .
That bass finish looks very good on that 'Lott' !
