#61
The manufacturing industry in the United States is dying. If someone in the U.S. has an idea for any musical instrument related product I suggest that we keep all aspects of production right here in the USA. And have it made locally.
When I designed my "capos" it was about five years ago, before I had even looked at Mr. Anzellotti's. None of these designs are a novel concept, just a proven style of adjustable bracket found on all types of assemblies for hundreds or thousands of years. I was asked to come up with something to install on extensions with poorly functioning stops. It seems like mine ended up being a similar concept but easier and cheaper to make. If you have files, a few drills, taps and a drill press you could make them. Also, the standoff distance or bracket width is adjustable - simply disassemble the two brass parts, belt sand until you have the dimension that works then re polish. I like the idea of an adjustable, easy to mount bracket. It just makes sense in many ways. With that said I think ebony fingers are much more comfortable and allow an individual, artistic touch. Kind of like decorating a bridge. Arguing about who's capos are most attractive is pretty dumb. I'd say a more important question is do you want to be at the mercy of someone else's product or design? No, you don't. Last edited by Vince Jesse; 06-01-2010 at 09:28 AM. Reason: ... |
#63
Now THATS one mean hand !! I'd hate to be in the pit next to you !! One could loose ones entire scroll (if not your life ) in a split second if something went wrong whilst trying to martial art the extension into tune ! I would opt to wear a bikers helmet or even have a sniper on standby in the wings just in case ! ![]() ![]() ![]() ![]() |
#64
If that were completely true, this forum would not exist. But the gist of your sentence is on the money. I want to know who were the "geniuses" who decided that America could have a vibrant economy without anyone making much of anything? Did they really think we could all just swap information and loans and that this would somehow lead us down a positive economic path? (Sorry for the thread derail.)
#65
![]() No, let's talk about 'FINE' tuning the extension Capos. Rob mentioned his full turn measurement (1/24th of an inch) which is just a tad over .040" (1 div. by 24). That is nearly a 'G' string in height. WAY, way too crude for my taste. I can adjust my Capos with the top screw and back nut just a tweak as the leather settles or if I change gauges of strings. If I use an Original Flatchrome at almost .110, or a Flex Stark at .106 or a regular Flex 92 e/c at .102 I can tweak the tension just right. That would be 1/10th the need adjustment from .106" to .102" which is .004", not .040". HUGE difference. Turning a screw 10x what you need is NOT a fine adjustment in my book. Not even close. Sorry! Some people just get used to what they have. Once you have seen the other side of the road, you may not go back. |
#66
The Manuf. in USA Rants are to be discussed in the Bull Pit. I moved one post here to the 'Pit.
If it's not about 'Show Your Extensions', then post it where it belongs. |
#67
If you can't get them handmade or afford them to the quality of the ones made by hand by the better Luthiers that do these then Rob's would be better than bad handmade ones. I would place them as an alternative but not as a premium choice, in my opinion. ![]() I am about to get three or four more extensions made in the next few months. These will be on the new inspired Storioni copy bass, the Storioni (former att.) bass itself, the Mougenot by Jeff and possibly the Malvolti labeled Florentine bass I just got. I don't seem to be able to do without one now that I've been using an Extension of this grade for the last several years. I played some Jazz sets last week and even used it there. Having it and not using it seems a waste, written for or not! (don't tell the conductor, please.. ) |
#68
[quote=wayne holmes;20746]
Pics don't sometimes? I have no idea why. That is an Extension from Jeff, the 2nd of 3 he has made for me so far. All 3 seem about the same master quality. The 4th is yet to come, on the Mougenot he is restoring now. |
#69
I have posted pics of most of the extensions I've had made but since my last pic post here I have had a few more done. Two of the basses have been sold already but there's no harm in showing off their extended heads. These include a Jacquet-Gand, the Schnitzer-Smith-Riccardi commission and the original Riccardi-Storioni.
![]() ![]() ![]() ![]() ![]() ![]() Enjoy.. ![]() |
#70
The above 3 extensions were by Arnold. Here are two more from Jeff Bollbach. One is the Mougenot and one the Neuner.
![]() ![]() ![]() ![]() The Neuner is also a Bass I use personally for just about any type of gig but the Storioni is currently my 'classy' Orchestra bass along with the Hart depending on which way the wind blows.. ![]() |
#71
Hi guys. I installed another C extension and would like to show it around here. This time I benefited from earlier experimentation and I'd like to think this one is a bit more refined. No need for the bottom of the extension to be flat and straight for the thumb because the side rail takes care of that duty.
Thoughts? |
#72
Side rail? Interesting. I wouldn't screw someing like that into my Scrolls but I can see the sharp gear edges can get painful. Practice Beethoven 6th's storm movement on the Extension, the individual 16ths and you will see with each bass what needs to be done. You can even buff the edges of the gears to get the sharp edges softened. One old bass gears, many of them are worn and smooth by now. My Tarr is very smooth now.
Speaking of the Tarr, the page isn't up yet but I have some pics. They are dark and I will probably re-take them or lighten them up for the page but here's a look at the Extension Arnold made for it; ![]() ![]() The fit of the Extension and String on and around the Scroll was a challenge on this being that the face of the head is so thin. Arnold made it work both artistically and structurally as well. |
#73
The rail was there before I got there but the owner of the bass makes great use of it.
As I finished this one up I was thinking about how much work these are. Very challenging. - they have to function well and be beautiful to look at. |
#74
And now for something completely different: I understand that C extensions have to be what they are when converting a standard bass.
BUT -- they do seem unwieldy. Now, regarding new construction, or in the event a bass has had its pegbox and/or scroll mangled to the point of having to be rebuilt anyway, and there is no historical reason to simply copy what was there, has anybody designed or executed 1+3 pegbox with the extension and stops integrated into the overall design and scroll, and not just as an add-on? |
#76
#77
Nice. Thanks.
#78
I'll post one last C extension I made as I seem to be honing in on a particular look. This is installed on a Calin Wultur "Elite" bass.
Any thoughts? |
#79
Very nice looking work.
#80
Thanks, Ken.
| Currently Active Users Viewing This Thread: 48 (0 members and 48 guests) | |
