Old 11-29-2010, 10:11 PM
Cool Neck dive?
Originally Posted by Adrian Bartol View Post
hello,
....anyway, i've noticed a problem when i play it stand up: the headstock falls a little bit towards the floor if i don't hold the fingerboard with my left hand... it seems the fingerboard's weighs more than the body what makes it a little bit unstable.
is there any solution? what can i do?
thanks for your time!
This is not a problem but perfectly normal with that body cut (similar to the Smith BT body cuts). Because the upper horn is shorter is the reason why you are getting the "neck dive", not because the fingerboard "weighs more" than the body.
What you can do to help balance it out is simple. Assuming you are a right handed player, just use the forearm of your right arm and rest it on or near the upper rear part of the upper body wing. The rear part of the upper body wing would be under your right forearm anyway. It would just be a matter of learning how to apply whatever needed pressure/weight from your right forearm to balance out the overall bass to your liking.
I have a Burner 6-String and a few BT model Smiths with similar body cuts, so this is something I easily adapted to without any complaint.
FYI: The Smith BSR body cuts have a longer upper horn. Because of this, the BSR balances perfectly on a strap.
Tags
burner 5 neck dive
