Here's a print of the "Original" and "New" settings.
Tim Bishop |
Many many thanks for the prompt and extremely informative replies. Just what I needed.
I have now gigged the bass in anger and it sounded fan=blooming-tastic. I had a huge grin all night. Notes I normally really have to articulate came flying out. The bass was really easy to play, is exremely well balanced and felt very light on the strap, no shoulder fatigue here !!!! One small issue, I would like more output from the bass if possible. The amp was cranked way higher than for previous basses ( Stingray % and Overwater Perception 5, both quite hot basses tbh ). I understand there is a gain trim, where is this please ?? FYI I have new batteries and the difference in volume between active and passive modes is minimal, active being slightly louder. Thanks all, Stewart |
On the Mid board, look for a small slotted dial (this is the trim-pot). The trim-pot dial is white in color and is housed and raised up a bit off the board . You will need a small flat-head screwdriver to make the adjustment. Clockwise will increase gain, counter-clockwise will decrease gain. This is a great feature and if adjusted correctly can be of great benefit to the player.
I generally adjust trim-pot to about 80%-90% (gain increase). Not sure what amplification set-up you are using, however, be careful not to overdrive the amp. I've not had any issue overdriving any of my Eden heads. But not all amps are the same.
Tim Bishop |
Thanks all, now sorted. Big increase in output, it was set to about 9 o'clock, now closer to 1 o'clock. Not overdriving any amps so thats good.
I owe you guys a beer next time you're in Glasgow. Thanks Stewart p.s. whilst I was adjusting the trim I was teaching my 7 year old daughter major and minor scales and arpeggios. What else do you do on a rainy Sunday afternoon ?? S |
