Old 03-19-2011, 07:15 AM
Which Knobs are they. The current model we use has Knobs we have used for over 20 years. They use a 1/16th inch size wrench. There is no exact metric size. If you use a metric that 'almost' fits, you will have the same problem you have now, maybe.
There are 2 screws in each knob. Loosen both to take off the knob. These are black rubber knobs with metal inserts. The old BT concentric smaller Treble knob has a smaller screw, the same as the bridge saddles .050"/inch. NO Metric substitute, only inch size will work or you will strip the slot.
Thank you for your answer!
It's the new ones.
Yes, I figured that out. The hex I tried to use were 1,5 mm.
Hope I've only messed up one screw.
If I'd like to buy new ones then?
Don't know the right terms but here I would say like M4x8mm to get the right size. What's the size of these I need?
