Good morning,
I've just joined the Bass Forums and after reading several posts and threads on various subjects, realize the depth and range of knowledge and experiences that are expressed here. It's a real privilege to take part. I'm most experienced with the electric bass, so after seeing pictures of the extended low string(s) on double basses, I'd like to verify the practical reason for this. I suspect it's to increase the string tension. If so, is this only applicable to the acoustic bass or can it also be applied to an electric bass? The few string makers that publish comparable tensions for a given gauge set, always show the E (or B) strings to have less tension. After comparing the sound and feel of a short scale Gibson EB2D with the longer scale of a Fender Precision, I realized string length (besides string gauge, type of metal and wrapping method) must have something to do with tension and feel or as well as a tighter sound - attack > decay. Since the Fender basses are rugged and relatively adaptable to modifications, I'm experimenting with simple ways of extending the E (and to a lesser degree, the A) string by various increments to see what the "feel" and "sound" difference will be. There is enough extra length of bare metal on my long scale E string to allow as much as 2" or more of extension. I could even go with an extra long scale (36") string for test purposes. I don't want to exceed the tension of the other strings...just come closer to it without straining the neck. I haven't yet seen any tailpiece designs that do this but the idea seems to have some credibility after noticing the extensions on double basses. I'm also testing various string angles from the bridge to the tailpiece, to see what effects this may have. I agree with some comments that Ken Smith has previously expressed in ultimately trusting ones "intuitive feel" for sound and touch over engineering specs and calculations. I am however, using tension and deflection gauges to measure my progress and compare differences with how it feels and plays. I'd appreciate any thoughts or experiences on this subject. Respectfully, Jack N. Sarasota, Florida |
The D'Addario company has done this already. They publish a string tension guide that has the tension of each of their strings for each instrument and scale length they are designed for, as well as the mathematical formula for figuring out what the tension would be for different scale lengths, for both electric instruments and classical instruments, including double bass, although the double bass chart is a separate pdf.
Now, of course, with the differences in double bass string manufacturing, not all strings will have the same tension, and one company's light might be more like another company's medium. The important thing is that once you know a string's tension for a given pitch and scale length, you can use the math to sort everything out. The only niggle I have with them is that they talk about "unit weight," when, more precisely, it should be "unit mass," but whatever. Notice it does NOT talk about string diameter, because depending on the manner of construction, the geometry of the wrap wire (flat, round, etc.), the amount of damping material, etc., two strings of the same diameter can have different mass, and two strings of the same mass can have different diameters. From the D'Addario string tension guide (since pdf's won't post): Understanding what determines string tension. In order to determine the tension at which a string will vibrate, you need three pieces of information: the Unit Weight, the Scale Length, and the Frequency of the string. You can use the charts in this brochure to get a pre-calculated tension for the D’Addario strings listed or you can use the formulas below to calculate the exact tension for any string using the scale length of your particular instrument. All of the charts illustrate string tensions for each string at a variety of pitches, in case you use alternative tunings. UW- Unit Weight. In all the charts and formulas in the brochure, unit weight is expressed in pounds per linear inch (lb/in). L- Scale Length. This is the vibrating length of the string. This is determined by measuring the distance from the nut to the bridge of the instrument in inches (in). F- Frequency or pitch. This is the pitch at which you will be tuning the string expressed in cycles per second (Hertz). On the following page are two fingerboard graphics detailing the various frequencies for the standard guitar and electric bass guitar.To calculate the tension of a string in pounds use the formula below,inserting the three variables described above: T - (Tension) = (UW x (2 x L x F)2) / 386.4 To convert the result into Newtons, simply multiply by 4.45. If you know what tension you want the string to have, you can calculate the string unit weight. You can then use the charts in this guide to locate a string with approximately the same desired unit weight. UW (unit weight) = (T x 386.4) / (2 x L x F)2 Now, after digesting that, then the differences in tone as a function of scale length have been researched by Ralph Novak, whose work I used in designing my fanned fret bass guitar and electric guitars. The following is, of course, for guitar, not bass or double bass, but the same principles apply: there is a difference in tone as a function of scale length, with all else being equal, the longer the scale length, the more and higher overtones a string can produce due to the tension increasing as the square of the scale length increasing. Finally, several companies have posted their tension specs for their various double bass strings in various contexts and scale lengths: 4/4, 3/4, solo. Most notable are Thomastik Infeld, D'Addario, Velvet, and a few others. Most notable by its absence is Pirastro, who still refuse to publish anything but their subjective labelings as to general category. And, as Ken says, it still comes down to what feels good for you. All these specs are meaningless in and of themselves. You can't use them like an engineer's reference manual to determine what string will be best for you. The best that can be said for them is that they are more like a naturalist's field guide to help you get in the general vicinity of a few possible selections based on an individual player's criteria, whether genre of music, cost, "feel," etc., and then do your own research to see what is best for you, consulting other players and teaching professionals. Last edited by Scott Pope; 01-20-2012 at 04:44 PM. |
There's one other detail I didn't address: break angle over the bridge. Generally, the greater the break angle, the more downforce this puts over the bridge, reinforcing sustain and the fundamental. The less angle, the lesser the sustain and the lesser the fundamental.
There is the bridge angle, bridge mass, after length, tailpiece mass, headstock/scroll angle, after length per string, break angle of the nut, nut material, nut width front to back, instrument woods, thicknesses, vibration abilities whether absorbing or reflecting mass of the vibrations, neck stiffness, and, and, and .................................... etc, etc, etc... There is no way to measure the overall tension-performance of anything on a bass and make that work the same on another bass. Have fun with your project. If you want lower notes on a Bass Guitar which is NOT a bowed instrument, add strings to it. Usually a low B below the E. Anything lower and you are kidding yourself. Most musical applications don't need anything below the E if down that deep. The response is just too slow and had nothing to blend with down there. usually the lower notes are used as an effect, not as a pulse for the normal bass part, jazz, classical, rock, R&B or what ever you play. |
All the information is very much appreciated and obviously complex. There are so many variable factors, changing with every instrument, shaping its own sound and unique, tactile response with the player.
Measuring (not calculating) the existing string tension (and string deflection at the 12th fret) on the low E string with my stock bridge will give me some numbers to begin my comparison. I'll then take similar measurements when I extend the string at various lengths back and at various degrees down from bridge level. I've got up to 3" of extra string length to try out and different ways of extending it from a shallow angle to a sharper one that puts more downward pressure on the bridge. I'm interested to see how these changes effect string pull and harmonic sensitivity as well as string tension. With the many possible ways that other components can effect change, I'm only looking at these two string-dimension variables for now to see where it leads. I'm looking forward to sharing what I find. Thanks again. |
