#41
Sorry. Just wanted to clear up the misinformation in this thread. |
#42
IF, I have to choose only one string for every bass, I would be in big trouble. Bel's work best on many basses but not all. Sometimes the grittier bite of a Flexocor or Orig. FlatChrome is just what the doctor ordered... |
#43
I've also heard that the Bel Ext C is the best out there. |
#44
I'm in total agreement Calvin.
My Bel Canto strings have been on my main bass (I only have two) for most of this year and will be staying put. They've settled down nicely - both for arco and pizz. The whole range sounds great. They're a joy to play. |
#45
I love Bel Canto strings.
#46
Well, here goes: the Bels GDA with the Spiro 3885.5W E have been perfect for my jazz & dance band gigs the last few months playing mostly standards. Now, for something completely different: I'm playing a cross-over country/rock/rockabilly gig this weekend. Last year I played this gig with Spiro Weichs, and of course, with so much sustain and growl that Spiros are known for, I could make them do what I needed to. The Bels, of course, are rounder and darker in tone. We'll see....
#47
Well, a little preamp gain and touch of compression can go a long way to make a gig work. Although it probably sounded fine out front, I was not happy with the darkness of the Bels for this particular gig, which comes as no surprise as they are really not meant for this kind of gig. But the bandleader liked it, and with strings being expensive, I'm not sure I'm in a position right now to have different string sets for different gigs.
Great experience, however. |
#48
Most basses do not do both orchestra bowing and jazz pizz equally well with the same set of strings on the same bass. If Bowing is your goal, Bel's are a good choice for some depending on the bass, tone and style you play. If it is jazz you are looking to do, I would not suggest these strings for most players for the reasons mentioned. |
#49
Now, for these "standards" jazz/dance band gigs I've been playing, the band leaders have really enjoyed the tone and the flavor of pizz the Bels produce. I like the feel of the strings and the relatively even tension across the board. Richard: yes, they are a little lighter than Spiro Mittels, but for the same reasons that I had to have a custom fanned-fret electric bass made, so I could keep playing in spite of old injuries cropping up and causing me grief, I won't be using any strings that are any firmer, including Spiro Mitts, and yes, I've also had my bass looked over for setup, as we all know that a good setup will do more for ease of playing than any set of light tension strings. I think you'd agree it's hard to get any more "playable" than the tension of the Bels, on an even shorter 40.5 mensure, (false nutted down an inch - and if you saw my left pinky you'd know why) with string heights at the end of the fingerboard of 4-5-6-7 mm on G-D-A-E respectively, with no buzzing at all anywhere, and even then, at the end of a 3-hour gig, I've still been known to soak my hands in ice water, and, well, we're not even going to discuss my wedding ring over my knuckle. Even at that, I know I could get some Velvet Blues, or a set of any of the different models of solo gauge strings and tune them down to get even less tension, but then they wouldn't drive my top sufficiently for tone and stability. For now, as long as I can deal with them, the Bels are, for me, a good balance of heavy enough tension to drive my top but light enough I can actually play them all night. Every body else's mileage will vary. If I play other gigs of the sort I did Saturday, I do have Jazzers in reserve, also purchased slightly used at a great price, that I will change into going forward. But for only two or three gigs per year of what I did Saturday, in an informal setting, I'm not too concerned. The bottom line (pun intended) is that on my particular bass the S42 Weich Spiros I had initially were so growly on my bass they almost sounded like Rotosound Swingbass electric bass strings by comparison. Ironically, for that very reason they were a great transition, tonally, from playing electric bass in these bands until I purchased my double bass a few years ago and got up to speed with it. Now, my band leaders really like what I'm doing with the Bels, and my opportunities for gigs have expanded. So as long as the guys who hire me like them, they're staying on. If they start getting too dark, or if I get asked to play with a different tone, or if my playing takes a different turn as to the balance of kinds of gigs I play, then I'll try something else. In the meantime, as my avocation, not my vocation, I'm having a great time with them and making enough on the side as a "weekend warrior" to be really fun and worth my while: I like them, my band leaders like them, our audiences like them. I get asked to play again: what more could a guy in my position ask for?! If arco had worked out for me, we'd be having a completely different discussion, of course. And I did change out the Bel E for a Spiro 3/4 3885.5W E for the very reasons mentioned: the arco tone on the Bel E was great, but the pizz was just too dark, and I changed it out as soon as it became apparent that my arco was not going to get appreciably better, and sold it down the line to the next guy working on arco. Last edited by Scott Pope; 09-10-2012 at 11:37 PM. |
#51
All good Scott, stay with the BCs. Hey, they worked fine for me in a gypsy jazz band a few years back.
I'm just a little worried about your lefthandedness and giving up bowing. I too am left handed, but play the traditional way - I started playing violin around 1960 and people just didn't consider switching an instrument around back then. Though, I do suspect that I am slightly ambidexterous. Look, my head is presently full of man-cold and I'm probably not thinking my best but getting on top of the bass bow takes a long time. Even after having been brought up on the violin, I remember bowing the bass for many years before I started to feel that I could really bow. My advice - just do a little bowing each day, say 10 minutes, as you start your practice. Just bow long notes and listen for a nice sound and try to enjoy that sound. I know Ken will disagree but, if you have hand problems, go German. Back off on the pressure - pull and push. Cheers yankee mate. |
#52
-- And BTW: after I got done posting last night, I got a phone call with a referral from our band's keyboard player, who is actually more of a bass player, to another gig, but who referred me instead of taking the gig himself because he believes I can read the gig better than he could. So life is good. |
#53
Oh, well, I've carried on too long. For what I am doing right now, the Bels are great. Thanks for everybody's help and encouragement. It's time for someone else to take a turn talking about them. |
#55
Hello,
Can someone please explain what was said in an early post about 'string spin'? I'm not familiar with this metric and I'm interested since I have a new bass. To avoid appearance of taking this thread off topic, I'll put in my .02c about bel cantos. I have Flexo 92's on my bass (less than 1yr old) and was reasonably satisfied but not totally. I wanted something darker and warmer, bassically I'm impatient for it to sound old! Put the BC's on there and immediately liked the deeper, thuddier sound of pizz. A little more gut-like sound, and lower tension than the Flexocors; buttery sound in some of the higher notes. The jury is still out on the bowing. I'm going to try them in a few rehearsals and see how it goes. I have noticed that some notes seem easier to start but will have to see how they do on vigorous spicatto passages. The tone isn't too different from the 92's, my basses character seems to override the string difference a little bit, but they do have a bit less of an 'edge', which is ok with me. I seemed to be getting a lot of scratchiness with the 92's though admittedly my technique has a long way to go. But if there is something about the BC's that is better for breaking in a new instrument, then I'd probably keep them on for a while. |
#56
One thing I have noticed about strings is that the famous players seem to stick with one type. Apologies if I'm wrong with this statement. I know this was true of NHOP and, I think, Ray Brown. Gary Karr seems to stay with the same strings too? Have they found the perfect string for their purpose? I suppose they have. I have a friend who is a trumpet player and he seems to be constantly trying mouthpieces. I suspect that all these modern 'super strings' are very good. Maybe we just need to stick with one set for a few years and look at our technique. Apologies, I don't mean to be critical, but I think I have a tendency personally to blame the tools when it is the workman (in my case). Just a thought I had.
#57
Hi Ken,
The bass I'm referring to is a new Thomas & George Martin 4/4. I guess I was trying to be a little vague to keep certain info on the down low. |
#59
Lol, thanks Bunny. I was hoping to avoid listing my name and then advertising that I have an expensive instrument at home. Oh well, too late for that. I guess it's need to know in relation to my question.
Hope I can find out about my inquiry anyway. . . |
| Currently Active Users Viewing This Thread: 12 (0 members and 12 guests) | |
