Old 11-29-2015, 08:48 AM
Default well..
I can only add that if you want interaction with replies from others referencing your work, then the text should be here and not another Link. You can put up several pics per post here. It's your project so you can do as you wish.
Here is an example; http://www.smithbassforums.com/showthread.php?t=1525
Old 11-30-2015, 01:20 AM
Chet Bishop Chet Bishop is offline
Chet Bishop is on a distinguished road
Default Bass Progress
Thanks, Ken! I appreciate the liberty you offer.
The bass is coming along slowly, as the weather has been troublesome, and I have been struggling with a cold...but, I did get the blocks shaped, finally. I think I may have to move the project to my son's shop where it is warmer and better lighted.
Used this rowdy beast to get the rough wood off:
It's a Kutzall disc, very coarse, and rips wood like crazy, but does not load up or burn the wood.
Then this little Stanley 100-1/2 plane:
It worked fine, though it is a little hard to control since it has such a radically curved sole.
Finally, I made this sanding block to finish the smoothing of each block:
It is two 2" PVC fittings cemented end to end, and a handle affixed, then some 60-grit corundum cloth affixed with the same PVC cement.
It worked very well, and the blocks are ready for ribs.
Thanks for looking,
Chet
Old 11-30-2015, 02:06 AM
Question working in the cold
Does working in the cold (with or without YOU having a cold, lol) affect the wood in anyway as far as humidity, moisture, shrinking or cracking?
Old 11-30-2015, 08:46 AM
It is easier to bend wood, keeping it hot, keeping the bending iron hot, etc. when the air is not hovering around freezing.
Needless to say, when gluing, it makes a huge difference in working time.
The next five things that need to be done are involving heat:
  1. Bending the ribs
  2. installing the ribs
  3. bookmatching the plates
  4. bending the linings, and
  5. installing the linings
So probably working in a heated environment would be a good idea. His shop is not only heated, it is a good deal larger than mine. :-)
Yes, I think moving the project to his place sounds like a winner. :-)
