Old 06-29-2017, 05:48 PM
Arrow Marconcini School, Bologna/Ferrara 18/19 cent, C-Ext, fully restored (IN STOCK)(PA)
This is a Beautiful old Italian bass made in the Guitar Style but with Violin Corners and added Scalloped Blocks on the Ribs of each of the 8 corners. This 3/4 bass has been played and admired by many great players including Leon Bosch, Stefano Sciascia and Gary Karr, the latter two favoring smaller Basses like this. This bass is extremely versatile having been used for Chamber music, Jazz w/Orchestra amplified, Orchestra section, Pit Orchestra w/amp and excellent for Solo performance as well, fulfilling the needs of any size ensemble or venue. String Length is 41" (104.1cm).
Measurements:
String Length; 41"
Top/Back Length; 43 3/4" top, 44 1/2" back
Upper Bout; 19 1/4"
Middle Bout; 14 1/2"
Lower Bout; 25 3/4"
Ribs (not including plates); 7 1/4" tapering to 4 3/4" at neck
~ Inquire ~
More pictures & Information can be seen here; http://www.kensmithbasses.com/double...ini/index.html
Name:	Marc. pictures 001.JPG
ID:	3510  Click image for larger version
Name:	Marc. pictures 002.JPG
ID:	3511  Click image for larger version
Name:	Marc. pictures 003.JPG
ID:	3512  Click image for larger version
Name:	Marc. pictures 004.JPG
Old 02-02-2021, 10:48 AM
Cool old pics..
A couple of friends that have enjoyed playing the bass as well as yours truly, in concert..
Gary Karr and Stefano Sciascia
ID:	3908  Click image for larger version
ID:	3909  Click image for larger version
ID:	3910  Click image for larger version
ID:	3912  Click image for larger version
Old 11-29-2022, 01:13 PM
Arrow Restoration pics, 2009-2011
In these pics you can see the Top work in-progress which was extensive. Also, on the inside you can see the partially 'kerfed' linings that were done after gluing in at construction in order to bend the thick Ribs and Linings together 'in-one' rather than adding the Linings after. This was probably a Lute/Violin maker as the bass has signs of both skills in one instrument. Also, the 16th century label is old, but not original but this bass was made in that style. The full finished bass still with the Luthier in the last pic before the bass was delivered to me at which time a final set-up was done afterwards. The restoration was done by Robbie McIntosh with set-up work also done by Arnold Schnitzer. The later added C-Extension was done by Keiran O'Hara as well as a later Back restoration a few years ago. I have played and performed on this bass for about 10 years. It's an amazing instrument.
Written on that old, possible forged 16th century label;
{Translated from Latin}
Viva fui in silvis
(I was alive in the wood)
Sum dura Occisa
(I was cut by the cruel axe)
Securi dum vixi tacui
(In life I was silent)
Mortua dolce cano
(In death I sweetly sing)
ID:	4031  Click image for larger version
ID:	4032  Click image for larger version
ID:	4033  Click image for larger version
Old 12-20-2024, 04:12 PM
Cool More of the 'Scallopini'..
This is such a fun bass to play The sound and volume is amazing.
ID:	4088  Click image for larger version
ID:	4089  Click image for larger version
