Old 10-04-2007, 01:27 AM
Originally Posted by Marcus Johnson View Post
.... on my bass, they feel quite soft and comfortable under my left hand, while under my right, they feel a bit stiffer and very precise. I don't remember having that impression from any other string, and it's pretty subtle. It works out well for me, because I can dig in with the right hand as much as I want, while left is pretty much free to explore without a whole lot of tension.
Still hard to explain, obviously. The arco tone is glorious.
+1
Just got my early 20th cent. German bass back up to NJ from Miami. I decided to put my new set of EP's on that rather than the Prescott.
The German is brighter and is more in need of a louder, darker string. The already dark and lush Prescott does fine w/ Spriro Mittels w/ a Superflex G. The brighter strings counterbalance its darker sound. The rusult is robust, but clear, to-die-for pizz sound. But I do long for easier bowing lower strings.
Just put the EP's on the German taking off newish Flatchromsteels that I was experimenting with.
First impressions: Piz; Deffinately thicker, darker, 'ropier' w/ more 'thunk' and less metallic 'splank' to the start of the notes. Nice warm G sound. Less pingy than Spiros or FC's. Nicely balanced set. Definately makes this bass louder. I can see what you guys mean about the E needing to break in. There's some growl down there, but not like Spiros.
Maybe a little more work than the FC's, but I'm enjoying the volume. Could be just what the Dr. ordered for this bass.
These are my first sythetic core string of any kind and they do seem to be stretching out over this first day and getting growlier and louder when I bring them back up to pitch.
Arco; seems pretty outstanding. All the strings including the lower ones get started pretty easily. More robust and pleasantly darker than FC's. Can't help wondering what they would feel like under the bow on the Prescott.
More later.
BG __________________
-Straight ahead and strive for tone
Old 01-23-2008, 04:19 AM
Dan Tice Dan Tice is offline
Dan Tice is on a distinguished road
Default EP Update?
Hey Brian,
Just wondering if you're still using the EP's. If so, how is the arco holding up now that they have some time put into them?
Thanks!
Dan
Old 01-23-2008, 03:29 PM
Default My 2 Cents
I've been using them for a couple of months now, but split between two basses. The E and A on my '55 Juzek are wonderful, especially under the bow. The fullest, loudest sound I have heard on this bass and I've been playing it for 30 years. I think I prefer Spiro Mittels for jazz pizz for a little more sizzle, but these work well. I have Obligato D and G on this bass and the combination is fine together. It seems that the Obli D and G are louder now, too.
On my other, older, German bass with a darker sound, I have the EP G in combo with Weichs and am very happy. More meat under my finger, less twang and darker sounding with the bow on the G string. This bass seems to like less tension, hence the Weichs.
Old 08-29-2008, 02:38 AM
NS LaScala, EPs, very satisfied both pizz and arco.
Old 01-24-2009, 04:31 PM
I put a set of EPs on just under a week ago and they keep stretching (going flat). Is this normal? How long do they take to settle?
Old 01-27-2009, 12:33 AM
They're settling - good pizz sound. I just put my Belcanto set back on.
Old 01-27-2009, 02:29 AM
Question ok.. now..
Please tell us how the EVs compare to the Bel's.
They are both each company's new 'wonder' string. What say you?
I have used them both but not on the same bass.
Old 01-27-2009, 07:07 AM
imho you should give the pirazzis some weeks to develop before judging
