Old 01-02-2008, 06:29 PM
Harry Scott Harry Scott is offline
Harry Scott is on a distinguished road
I've personally never experienced this and this is the first time I've heard something like this (which doesn't mean anything), however, maybe it's a matter of technique or the distinct differences in bass design. For the sake of my reply, I will assume by "digging in" you mean getting under the strings?
A couple of things:
1. Maybe your Bridge P/U height is set too high? Whether you have a light touch or not, and given the appropriate technique of playing at the Bridge P/U (i.e. not overly aggressive), I can't imagine how you would have a problem with this, unless of course, the P/U's are set too high (i.e. too close to your strings) for your playing style.
2. I would also agree, if you've grown accustomed to playing another bass with a different feel, you most likely would need an "adjustment period" (i.e. time to adjust to a different bass). An "adjustment period" would apply to ANY bass different in design from that which one has grown accustomed.
3. You should have reasonable, ample range to adjust the P/U height on your Smith (up or down) on either P/U accordingly.
When I play anywhere on TOP of the Smith Bridge P/U, the tips of my fingers are only grazing the top half or tops of the strings (depending on the sound I am trying to get). If I feel the need to dig in, I usually do so anywhere from the leading edge (i.e. neck-side) of the Bridge P/U towards the EOF (i.e. end of fretboard).
I would consider myself a dynamic player as far as technique is concerned. In other words, depending on what the tune demands, I may play with a light touch; I may play with MUCH aggression, or, somewhere in-between. I find that Smith Basses provide great flexibility: With the Smith Control's and EQ, I can dial in anything, no matter what my technique-of-the-moment may be; I'll adjust accordingly.
Hope this helps.
Thanks for the alert, Tim. There IS an arrow to indicate "more post" on the quote section of my previous post...I didn't see the rest of the post - which does address the issue. The whole thing has improved a bit in the last couple of hrs but unless I'm mistaken my rear P/U was a little high.
I don't dig in that much (i.e "under the strings"...I only use "pulling" as in "pulling bass". Just a kind of slang). Ordinarily my fingers extend a few millimetres towards the body beyond the string..but sometimes more millimetres perhaps.
I'm "adjusting". I think the Smith sound is worth the work. Bases are so individual. When I find one that "works" I should snap it up.
I'm working on this one though. I think I need an Eden.
As usual, thanks.
Btw, do different makes of bass have different spacings between the frets?
